I noticed the other night that my xenons were doing almost nothing to light the road. With 180k on the clock, my high beans (obviously) and even fog lights did a much better job of lighting the road up. I did some searching but all I came up with was cleaning the reflector housings and new bulbs. When I tore my projector housings apart I found this:
There was no reflective material left to "clean". The driver side was even worse than the passenger side pictured above.
my bulbs were in pretty rough shape too, so I ordered a new set of aftermarket D1s bulbs off of amazon.
After searching a few other forums, it seems like the only reasonable solution (having the reflectors recoated is pricey) is to "coat" them with some $9 aluminum HVAC Tape from Lowes.
I cleaned the housings with alcohol and cut/placed tape in each housing
After polishing
I covered a few of the other internal/moving parts that could also be absorbing light
I did one completely, before the other so i could do a side-by-side comparison. There is a big difference, even in the daylight, and I don't even have the new bulbs in yet. I'll report back when they're installed but even now, this is a huge improvement
