Hi
My Audi A4 TDI 2010 (B8) driver's door not locking or unlocking with key fob, other doors are fine. When I press lock the red light stays on. I'm using the key to manually lock or unlock. VCDS showed me the following.
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000102843545
Coding: 011002204001410001
Shop #: WSC 06325 000 00000
VCID: 479DBD97F6582F26159-8012
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
I bought used door control module(8K0 959 793 E) from ebay and replaced, but not worked, still showing the same fault. I've seen lot of threads with this problem but the reason seemed to be different in each case. Can someone experienced tell me what could cause this problem, Can Audi dealer only fix this?
Thanks
John
