Results 1 to 3 of 3
    Jan 16 2016
    Hastings,MI
    No fire, car will crank but will not fire.
    I have a 99 A4 1.8t. Bought car off a buddy. And he said it ran when sat for 3 years. Replace fuel pump, fuel relay, crank sensor, drained old fuel, new plugs. When you spray a little bit of ether in the intake car will run. Other then that will not fire up. Got engine code 1237-1240 all 4injectors open Circuit. Any help would be great.
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    With a car that say that long I'd just replace all possible variables man. Do the relay, injectors, and wire harness
    Veteran Member Three Rings Waspjr's Avatar
    Feb 03 2013
    Wifes jacked up f350 on 24's custom paint job landrover lr3
    Osoyoos/bc/canada
    Do you have a crank signal ? And are your injector wires not chewed from mice
