Results 1 to 4 of 4
    Established Member Two Rings Quattro06's Avatar
    Aug 11 2008
    2006 Quartz Gray A4 2.0T
    Dublin, OH
    Loss of Boost Pressure while Driving on the Highway - Help Please
    I have recently been experiencing loss of boost pressure when I drive on the highway for periods longer than an hour or so. Normally I get around 18-19 psi peek with a small drop down to 16-17 psi but now I will only get between 4-6 psi max in any gear. This has happened a few times with the first time happening while I was down at the Tail of the Dragon back in November while driving on the Cherahola Skyway. Once I turn the car off and let it sit for a few minutes everything is back to normal so I'm really lost at what to do next.
    The last time this occurred it happened on my 30 min commute to work, so it seems like it is starting to happen more often on shorter drives. When it happened the last time I got a CEL which I scanned when I got home from work. The 3 codes I got were:
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
    Component: 2.0l R4/4V TFSI 0070
    Revision: --H10--- Serial number:
    Coding: 0104010A190F0120
    Shop #: WSC 01286 386 08256
    VCID: 2B5EEE7B8AF7CC66D8-807E
    3 Faults Found:
    008567 - Bank 1; System Too Lean off Idle
    P2177 - 001 - - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 230744 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1676 /min
    Load: 32.9 %
    Speed: 66.0 km/h
    Temperature: 90.0∞C
    Temperature: -3.0∞C
    Absolute Pres.: 970.0 mbar
    Voltage: 14.097 V
    000313 - Oxygen (Lambda) Sensor B1 S2
    P0139 - 004 - Response too Slow - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 232075 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1642 /min
    Load: 10.2 %
    Speed: 79.0 km/h
    Temperature: 90.0∞C
    Temperature: 8.0∞C
    Voltage: 14.351 V
    004372 - Oxygen (Lambda) Sensor; B1 S2
    P1114 - 008 - Internal Resistance too High - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 232075 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1642 /min
    Load: 10.6 %
    Speed: 79.0 km/h
    Temperature: 90.0∞C
    Temperature: 8.0∞C
    Voltage: 14.224 V
    I'm wondering if it's the PCV or a vacuum leak somewhere. Any help on what to check/look out would be greatly appreciated. Thanks so much!
    2006 Quartz Gray Metallic. Tint: 50% front, 35% back. Custom Tint Tail by CSN Motorsports. Deval CF spoiler. CF wrapped B-pillar covers. MTM Stage 2. MTM Catback. 034 HFC. Techtonics DP. CIM boost gauge. Forge DV. Votex Side Skirts. 3M Di-Noc wrapped trim.
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Generally the lean running would be a vaccum leak. Which diverter valve do you currently have?
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Aug 11 2008
    Dublin, OH
    Currently running the Forge diverter valve.
    Account Terminated Four Rings
    Oct 15 2013
    the one time i got a code for low boost pressure the air filter was plugged up. i cleaned it and the car ran great.
