Hey guys, have owned my b8 avant for a few months now and just purchased the ecs tuning boost gauge kit. Just installed it and not to my surprise it isnt calibrated correctly due to the elevation i live at. Does anyone have this boost gauge installed on there car and know how to calibrate it? It is not like the podi gauges where there is adjustment controls in the sender unit. I thought maybe it was reading correctly once the car was running because at idle it was sitting at -20in/Hg which is where my b6 sits and i was hitting 13psi of boost which is just a bit high from the stock 10-12psi (my b6 was the same way on a stock tune, hit 12-13psi). Upon comparing gauge readings to requested/actual readings in vcds however the gauge readings are off the same amount that the calibration is off. Im hitting 17psi and requesting 17 psi per vcds logs. this really has me scratching my head, because i have not tuned the car and bought it CPO from audi denver (i assume audi would never CPO a car that was TD1 or had an ECU with an overwritten stock file.
any help on calibrating the ecs gauges and why i would be hitting 17psi would be much appreciated. Thanks.
