So I've noticed that at relatively low speeds, when changing from 1st to 2nd, there is a "thunk" noise when I depress the clutch. I don't feel anything through the pedal, and the car doesn't jolt at all, there's just the noise. I have searched everywhere and the only info I found was on an E36 BMW M3 forum which said the issue could be solved by changing the gearbox and diff fluid. My car could probably use a gearbox oil change as when it's really cold, I have to double clutch to avoid grinding second gear until it warms up, I haven't really looked into it, but I'd assume that the diff fluid would probably need changed as well. Do you guys think the thunking noise is related to that, or do I possibly have a perished gearbox or diff mount causing the issue? I know my Golf is due for a gearbox oil change, but it doesn't make a thunk, then again, fwd Golf and A4 Quattro, Apples and Oranges.
Any help is greatly appreciated!
