The auxiliary fan (drivers side in front of the rad) seems to always be cycling on and off. At least when the car is off, I haven't really noticed when the car is running.
Background:
2003 allroad 2.7 120K - Orig factory battery
I replaced the clutch fan with an EFK this summer, I am not sure if this is when my problem started, but at that time I also pulled the auxiliary coolant pump (under intake) and replaced that with a fitting instead.
Problem:
I didn't seem to have one until yesterday when the car seemed to take an extra few seconds to start. This morning when I went to start the car, it was completely dead, didn't even register on the dash voltmeter.
I have no problem replacing the battery (as it is orig) if necessary, but it seems that I have a bigger problem causing the dead battery anyway. Could this be the fan control module or perhaps something to do with the wiring I installed?
Thank you in advance
Joel
