Results 1 to 18 of 18
    Veteran Member Three Rings GT-R & S4's Avatar
    Jun 05 2011
    Central Florida
    Better Looking Replacement for Rubber S4 All Weather Floor Mats
    Since it is Winter, I removed my custom Lloyd's floor mats and put in the rubber S4 all weather mats. My problem with them is that right after cleaning them, as soon as you step on them there are footprints. After a day or two you have several footprints and dirt. I am very careful before I get inside the car, by stomping my shoes, scraping the soles on the pavement, taping the side of my shoes on the side of the vehicle, etc. I'm wondering what type of floor mat would look good, but serve the purpose of a Winter driving floor mat, but hide the dirt and such? Cocomats(sp?)?
    ‘20 Kyalami Green RS3
    PAST
    '21 Corvette//'18 Cadillac ATS-V Championship Edition
    '14 Jaguar XF-RS//'19 Corvette Grand Sport//'18 Audi S5//'15 Maserati Granturismo Sport
    '17 MB C63 AMG//'17 Lotus Evora 400//'15 Audi S4//'14 GT-R//'08 Pontiac G8 GT
    '11 Cadillac CTS-V Wagon//'09 GT-R//'12 Mitsubishi EVO MR//'07 BMW M6
    '09 Cadillac CTS-V//'05 Audi S4//'06 Infiniti M35 Sport//'04 Subaru STi
    '02 Subaru WRX//'91 GMC Syclone//'86 Buick Grand National//'64 Rambler
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Weathertech
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Mar 21 2015
    Weathertech for the fronts hand down
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    nano-tech invisible floor mats!
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    I had the Lloyd's mats and then switched to the weathertech mats. I don't think there is anything you can do to avoid the footprints, grime, etc from building up and showing. The only difference with the two is that the weathertech mats are easier to clean. They probably show the grime a little more but it is nothing to take them out and wash them off. I've had mine for several years and they are holding up well. I also got the trunk liner.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I do not have them in my S4 but do have weathertech in my Tacoma and they are awesome!
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jun 05 2011
    Central Florida
    The problem with a plastic/rubber floor mat like the Weather Techs is that they will still show foot prints and accumulation of dirt and such. My wife has them in her vehicle and I can't stand how dirty they look all the time. What about those cocoa fiber mats? Would they absorb water and, "hide", dirt, depending upon the color/shade of the fibers?
    PAST
    Mar 21 2015
    You wash and vacuum the floors in your house don't you? The floors in your car are probably more dirty then the house, you need to clean them. That's the dirtiest part of your car.
    Nov 11 2010
    Minnesota
    They make Lloyds mats that have a pattern on them. I had the patterned ones that did hide some of the salt and dirt stains but they didn't have very high edges to them so it didn't protect the carpet underneath very well. The new designs might be different. That's why I switched to weather tech.
    Jun 05 2011
    Central Florida
    What a revelation. I clean my mats once a week, and in between I usually pull them out and shake them to get the loose dirt off.
    PAST
    Jun 05 2011
    Central Florida
    Thinking of something like this:
    http://www.cocomats.com/products/
    PAST
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by GT-R & S4 View Post
    Agree. I have weather tech all around and in the trunk. I wipe them off every other day or as needed. I simply keep a mixture of Murphys Oil Soap and water in a spray bottle. I add just a little bit of Optimum no rinse to it to help float the dirt up and then use a set of microfiber rags I have specifically for this use and in 30 seconds they are like brand new.
    I'm a stickler for a clean interior though. I think weather tech are a must for snow and salt areas. After a day of travels, even with clapping off my shoes, there's often enough water safely traped in them to soak a microfiber rag. I can't imagine not having them. They've been a go-to mat for my vehicles year-round for years now.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    Quote Originally Posted by justr0 View Post
    Weathertech
    /thread
    Apr 04 2012
    MSP
    Not going to keep the slop from getting into your floors.
    Carpet floor mats are not good in the winter... the rubber type is the best. Unfortunately they are not all that sexy looking... function over styling in this case...
    Weathertech has nice brims to hold more slop protecting your floors the best... which is the reason you want them... if you don't like them looking messy then you just have to clean em more often... carpet mats also end up looking like shit in the winter.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Check ebay for rev mats. Thats what i have
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jul 08 2015
    Looks like kitchen mats lol
    Jun 05 2011
    Central Florida
    Quote Originally Posted by JeriQo View Post
    Well, everyone has different tastes. I do admit, though, some of these cocoa fiber mats look like something by my kitchen door, ha-ha. But others look really good, and by the fibers and texture, appear that dirt wouldn't show up so easily, as in the case of rubber mats. As another poster pointed out, most floor mats to be used during the Winter months won't really look good, since most would be like the stock rubber mats that come with the S4, or the Weather Tech variety.
    PAST
    Jun 05 2011
    Central Florida
    Quote Originally Posted by DBL R View Post
    /thread
    Oh, we have to close the thread now?
    PAST
