Results 1 to 10 of 10
    Jan 16 2016
    Fresno,ca
    Steam from radiator ..
    Hi guys I just bought this car is 1.8t Quattro model...so what happen was I drive the car for awhile and I see a lil steam came from the radiator by the passenger headlight....sometimes smoke come out but sometimes it doesn't....coolant level, windshield wiper is good and I don't see anything leaks under the car....it just happen sometimes and what could be the problems? Thanks you..I did search but none of their problems like mine...so if anyone have any input please let me know thanks in advance
    Aug 26 2005
    When water or moisture gets on the outside of the radiator, when the thermostat opens and hot coolant begins flowing through the radiator, the water on the outside of the radiator turns to water vapor/steam as the radiator heats up. Or there is a leak in the radiator, usually at the tube sheets where the cooling tubes pass into the end tanks.
    Vorsprung durch Technik
    Jan 16 2016
    Fresno,ca
    Alright thanks
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I'll just leave this here and slink away: Clicky click®
    Jan 16 2016
    Fresno,ca
    I actually found where the leaks from and steam...is actually came from coolant feed line from the turbo....with the blue arrow..how difficult it is to replace those and which part should I ordered...
    http://www.a4mods.com/pics/turbo/IMG_0889a.JPG
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Ive got a used cooling hose that you linked from a padt out i did. If you're interested send me a PM
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Jan 16 2016
    Fresno,ca
    Guys u see where my flat head at....the coolant came from inside the bolt there...and which part should I get to repair this...and does this leak very common in 1.8t? Sorry I just got the car last week...thanks
    Feb 12 2008
    Michigan
    I'm guessing a new crush washer would fix that leak
    Aug 26 2005
    Quote Originally Posted by Fast4esT View Post
    That is a metal to metal compression fitting, no copper crush washer used there.
    Apr 07 2011
    I would say you're either gonna need a new coolant line or you're gonna have to tighten that one up and see what happens.
