Results 1 to 40 of 47
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    ECS – Front 2 Piece Brake Rotors
    So installed these ECS Front 2 Piece drilled and slotted rotors on my S3 today:
    https://www.ecstuning.com/Audi-8V_S3...raking/Rotors/
    Need to put some miles on before I can give a review of the rotors. I had these rotors on my 1M Coupe and they were excellent, so I’d assume the same for the S3.
    Install was easy enough, fitment is great. Look great on the open wheel.
    In the next few days I will install the StopTech Rear 1 piece drilled and slotted (https://www.ecstuning.com/Audi-8V_S3...ors/ES2996766/ )
    For those wanting instructions on replacing the rotors see below. Also note that NEW carrier bolts are required each time you remove the carrier. Apart from the obvious tools you will also need a 200Nm torque wrench, breaker bar, sockets. Scrub off the rust and a good idea to put some anti-seize on the hub before attaching new rotor.
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Nice write-up. Looking forward to the review!
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Apr 11 2012
    Nice! Any pictures from a little further away?
    Mar 30 2015
    Australia
    Quote Originally Posted by will13k7 View Post
    Sure. I'll do some more photos next weekend with the StopTechs on the rear too.
    Oct 30 2012
    Arizona
    Those look good..let us know if you can "feel" the weight reduction of 5+lbs per rotor. Interested to know. Thx
    Established Member Two Rings m3brad's Avatar
    Jul 22 2014
    Midwest
    subscribed
    Oct 02 2006
    Wadsworth,OH
    Looks great!
    Thank you for the review/install guide and posting pics!
    Jason
    Mar 30 2015
    Australia
    So after a week of driving my initial thoughts on these rotors are that they have a noticeably better bite over stock with OE pads. No vibes. Look great. For those not wanting to spend huge on a BBK, then these rotors will do you well.
    Will be installing the StopTech rears this weekend.
    Apr 11 2012
    did you go with stoptech rears to save some dough?
    Mar 30 2015
    Australia
    Yes, $250 cheaper and IMO rears don't need 2 piece on an S3. The StopTech's match the ECS front design + added performance and cooling.
    Had to chuckle at the ECS "Made in China" debacle, while the StopTech's also made in China :)
    Apr 11 2012
    nice! its going to look great.
    yep, just because it's made in china doesn't mean its low quality.
    Mar 30 2015
    Australia
    StopTech rears installed today
    Oct 30 2012
    Arizona
    Looks really good and more aggressive.
    Oct 02 2006
    Wadsworth,OH
    Definitely match our 2-piece rotors really well!
    Jason
    Jul 22 2014
    Midwest
    Quote Originally Posted by roadrunner_oz View Post
    Any install tips for the rears?
    Jul 22 2014
    Midwest
    Quote Originally Posted by m3brad View Post
    Anybody??
    Mar 30 2015
    Australia
    Yes, you need a special 14mm Triple Square (stubby) socket tool to loosen the carrier. Torque specs are 90Nm with and extra 90 degree final turn.
    Socket required:
    Mar 24 2016
    UK
    Hi Roadrunner thanks for the awesome post and detailed how-to and pics.
    I'm in the UK and have just ordered the ECS 2 piece rotors from awesome GTI together with the stainless original fit full brake line kit and have Castrol Rect Performance dot 4 fluid ready for a full fluid flush.
    Really looking forward to getting these on ! ;o)
    Mar 24 2016
    UK
    Also quick question re. these being directional - are there markings on them to show which side is which ? Pretty much going to work from these pictures.
    Is it worth painting the hats at all before fitting or are they unlikely to corrode being alloy ? Painted my OEM hubs twice so don't want to have to do these once fitted.
    Cheers ;o)
    Oct 02 2006
    Wadsworth,OH
    There should be an indicator depicting which is left and which is right. But if not you want the slots and drilled holes to face forward in a "digging" fashion not backwards in a "sweeping" fashion.
    Jason
    Apr 27 2010
    West Chester PA
    Where are you getting all these nice diagrams and guides from? Is there a PDF for the car? I'd love to have all the torque specs and diagrams like you keep posting. Thanks.
    Socket required:
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
    Mar 24 2016
    UK
    Jason
    That's great - thanks Jason !
    Mar 30 2015
    Australia
    Quote Originally Posted by JimmyDever View Post
    www.erwin.audiusa.com
    Pay for a 24 hr subscription and download all the repairs manuals and more
    Apr 27 2010
    West Chester PA
    Ah you must have told me this on another thread, now i remember this site. I'll check it out. Thanks.
    Mar 30 2015
    Australia
    Quote Originally Posted by reyoasian View Post
    are the slotted ones 2-piece as well?
    The ECS ones are, not the StopTechs. Really unnecessary to have 2 piece on the rear of a S3.
    Mar 24 2016
    UK
    Just wondered if anyone has the technical spec for bleeding the brakes - what is the correct sequence and do I have to do anything with the ABS pump using VCDS or bleed the master cylinder ?
    Thanks in advance.
    Mar 30 2015
    Australia
    Quote Originally Posted by Rob2k68 View Post
    Thanks in advance.
    LHD:
    1 - Left front brake caliper
    2 - Right front brake caliper
    3 - Left rear brake caliper
    4 - Right rear brake caliper[/QUOTE]
    RHD:
    1 - Right front brake caliper
    2 - Left front brake caliper
    3 - Right rear brake caliper
    4 - Left rear brake caliper
    Mar 24 2016
    UK
    LHD:
    RHD:
    4 - Left rear brake caliper[/QUOTE]
    That's awesome - thank you so much ;o)
    Mar 30 2015
    Australia
    RHD:
    That's awesome - thank you so much ;o)[/QUOTE]
    Not sure why Audi do from the closest to the reservoir to the farthest? BMW does the other way from farthest to closest.
    Mar 24 2016
    UK
    I'm struggling to get to the rear upper carrier bolt can't get my socket on it due to the upper link - any suggestions very welcome ;o)
    Oct 30 2012
    Arizona
    The previous post has that short stubby triple square pictured....do you have that one? is yours too long?
    Mar 24 2016
    UK
    Mine is the M14 bit built into the 1/2 inch socket like a torx socket in appearance so yes it's too long. I've ordered a shorter one 43mm long for an impact driver so hopefully that does the trick. ;o)
    Mar 30 2015
    Australia
    yes, need a stubby M14, else drop the control arm.
    Mar 24 2016
    UK
    Hopefully the impact bit I've ordered will be short enough I'll also call AUDI to see if they sell it. Failing that, what's involved in removing the upper control arm from the hub ?
    Thanks for your help ;o)
    Mar 24 2016
    UK
    Just for comparison could you measure how short your stubby M14 is please - the one I've ordered is 43mm.
    Thanks again ;o)
    Oct 30 2012
    Arizona
    Looking to either get these and make my own adapter for some calipers or get a STOP TECH BBK.
    Just wanted to check up and make sure there rotors were holding up?
    Would you buy again or get a BBK?
    Thx
    Mar 30 2015
    Australia
    Quote Originally Posted by A20V200 View Post
    Thx
    IMO, BBK on the S3 is overkill unless you are seriously tracking the car, but then you'd probably want a car which is more suited for the track. The ECS rotors are great and give a good sharp bite with OE pads. I ran these ESC rotors on my 1M Coupe previously and they saw heavy track use with zero issues (unlike the OE rotors which kept causing vibes)
    Jul 22 2014
    Midwest
    I've had mine on all four and love 'em. Two roadcourse track sessions and no issues. I also have ECS's SS brake lines installed and high temp brake fluid. The additional pedal feel is confidence inspiring, but I can't honestly say if it's due to the rotors alone. I've always updated my lines and fluid on all my previous cars that were put on the track.
    I agree with Roadrunner on the BBK comment. I'm not the track rat I used to be and find that my improvements I've made are ideal.
    Oct 30 2012
    Arizona
    Good to know that you track yours with stock calipers. Same thing with me, I only will hit the track 1-2 times a year, I was thinking rotors and maybe more aggressive pads and the SS lines.
    Jul 22 2014
    Midwest
    Failed to mention, I run EBC yellow's up front for track sessions. Not diggin' the dust, but medication helps
