Results 1 to 6 of 6
    Oct 13 2015
    Scotland
    Questions regarding 19" alloys?
    Gents
    I've just bought a secondhand set of OEM 9x19" ET33 Peelers. Two questions I have are:
    1. What tyre pressure should I use?
    2. Will I need to buy longer bolts or will the original ones for the OEM 18" alloys be okay?
    Thanks
    James
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by James777 View Post
    Gents
    Thanks
    James
    Maximum tire pressure is on the side of the tire, but I think OEM is like 35psi? I believe the same bolts should work. Rule of thumb is to have 4 threads in the wheel hub.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Oct 13 2015
    Scotland
    Thanks for the reply JDillon15. With regards to tyre pressure, I was wondering what people, who were running 19" alloys, set them to.
    James
    Jun 07 2013
    West
    Always use the tire pressure listed on the door jamb (when using the OEM spec tires). NEVER use the tire pressure on the sidewall - that value has nothing to do with the car - it is only the tire's maximum. For your application, use 42F, 38R to closely match load carrying capacity of the OEM tires. Regarding the bolts, you likely will not need new ones, but to check, count the threads the OEM bolts grab with the OEM wheels. Your 19's should grab the same number of threads. Here is an excellent source for bolts:
    http://www.otisincla.com/
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    40-45 psi should be just fine for 19s on our cars. I think I run 40. If you're taking it to the track on them, which you shouldn't be on 19" wheels, you're gonna want to closely monitor the pressure after every session. Otherwise, just buy good tires... or tyres haha and you'll be set to roll!
    Oct 13 2015
    Scotland
    Concavitor
    Thanks for the info.
    pwest15 - also thanks for the info. Funnily enough, I've just read through your engine rebuild. Most enjoyable!!
    James
