Results 1 to 6 of 6
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    Armrest lock fix "free"
    Hey guys,
    Recently took my 14' Q7 TDI in for service and asked them to take a look at the armrest lock not functioning. They tell me the only way to fix it is to replace the entire armrest, parts and labor $750.00 usd. I decide to explore the issue myself.
    After opening the armrest this is what I discovered. An "L" shaped metal spring held by thin plastic... wtf was Audi thinking in engineering this so poorly? Something that will have so much use in it's lifetime and they hold it in place with thin walled plastic.
    Check out the pictures below where the plastic broke on the 2 pressure points. I put the broken pieces back with gorilla glue and then applied plastic epoxy all around the "spring holder" to make sure the pressure doesn't break anything ever again. Put it back together and so far so good!
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Nice find! Looks like I have a project today.
    Daniel J
    @gtg_drives
    Junior Member Two Rings jes's Avatar
    Oct 10 2013
    California
    Question 2013
    Is that the "double" bin? I have a double decker lid, top half is 1/2 storage, with lid & latch on left, cup holders on right. I don't see any evidence of screws to get to the latch... Seam between parts is very small... maybe an upholstery trim tools to pry it apart?
    Veteran Member Three Rings SeattleiteA6's Avatar
    May 08 2015
    I'm curious about this too - want to fix my wife's busted console latch this weekend!
    2014 S6 Phantom w Black Int & Carbon Atlas//B&O//Innovation//Black Optics//RS front clip//E-code Dynamic Tails//Carbon Diffuser w carbon tips//VCDS -15mm//Straight Pipes//JB4
    2018 Q7 Night Black w Black Int//Technik Trim (CAN origin)//Luxury Pkg//Black Optics//Adaptive Air//euro tails and other mods forthcoming...
    2013 Q7 3.0T Prestige S-Line Plus
    2013 RS5 Ibis w Black Int//e-code tails//20" HRE FF01
    2012 A6 3.0T Prestige//Sport Pkg
    Registered Member One Ring roadmandriving's Avatar
    Apr 01 2020
    elliot
    Thought this would help because I followed the video and it was better then other videos encourage you to bend the hinges in and risking you to snap the hinges!
    I was searching ages for a tutorial video and I think this covers everything.
    https://youtu.be/WzS-ZPJU-Yc
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    What part of the video was helpful for the Q7 lock? It's not the same center console arm rest, so not sure if I was missing something.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
