    Registered Member Three Rings
    Feb 29 2004
    2005 Sebring S2000
    DubC, PA
    Angry Guess this sound....
    Ever since I've dropped my car on intrax sport springs, i've gotten this wierd whoomp/clunk noise. It is very hard to describe. It's only when the wheels are turned all the way either way (like turning in or backing out of a parking spot).
    Now...it really doesn't sound anything like rubbing (plus there is really no way I should be rubbing, i'm running 19's with 235/35's, et 35, and a mild drop). The sound almost sounds like its coming from under the hood or near the firewall, not from the wheel wheels. It's also not anything like the metal on metal ticking sound that was the bad wheel bearings I previously had. Any thoughts?
    Registered Member Two Rings zemaster's Avatar
    Sep 11 2005
    84 S10 pickup, 97 honda accord SE, 2003 Audi 1.8t
    Memphis TN
    Sounds like when you removed the shocks to put on the front springs you didn't compress the spring all the way and tighten the bolt on top of the shock completely...does it make a clunk sound when you go over bumps? That is what was wrong with mine.
    Black 2003 Audi A4 1.8t 5spd FWD
    Tinted, VAG'd, Koni C/O, APR snub mount
    Neuspeed SS
    ...handling and shifting bliss...
    soon to be REVO'd
    Registered Member Two Rings A4Alain's Avatar
    Jun 13 2005
    Audi A4
    Studio City
    I have the same Problem. I dunno what it is eather!!
    Veteran Member Four Rings A4Technik's Avatar
    Aug 08 2005
    Porsche 944 Turbo / Audi A4 Front Trash
    Corona
    I had that sound it seems to be coming from the power steering when you make a full u turn.
    Garage:
    1993 KS Auto Burnout Widebody Rx7
    2005 Kraftwerks Supercharged s2000
    2006 Evo IX MR
    2005 Audi A4 1.8T - Sold
    Go Fast Goodies:
    K-03 Sport | ER Sport FMIC | ER Test Pipe | ER Rebar | EVOMS CAI w/ HKS Super Mega Flow | Neuspeed Catback | REVO BI | BOSCH 380cc Inj. | STRATMOSPHERE Hyperboost DV
    Veteran Member Four Rings Nevaeh Speed's Avatar
    Jul 19 2004
    01' MK4 Golf 1.8t,08' 2.0t GTI
    Lancaster, Ca
    Yeah you didn't tighten the top nut all the way. been there done that. I hated that noise. Another thing I did was spray thing suspension down white lubricate, just to see if it helped... Never have heard that nosie again.
    Please no more IM's. I'm no longer on this board. If you need anything I can be found at vwvortex.com under the Golf MK4 section under Nevaeh_Speed... Also on Dubberzine.com under Neaveh Speed... 1000rr.net under Nevaeh Speed.
