Results 1 to 20 of 20
    Feb 24 2004
    Minneapolis
    Code: Too lean at idle
    Got a CEL a couple days ago, took note and cleared it. Now it's back. Same codes:
    Address 01: Engine Labels: 06F-907-115-AXX.clb
    Control Module Part Number: 8E0 910 115 M HW: 8E0 907 115 D
    Component and/or Version: 2.0l R4/4V TFSI 0060
    Software Coding: 0104010A190F0120
    Work Shop Code: WSC 69123 444 131735
    VCID: 2B553CC58AC6E966F4-807E
    2 Faults Found:
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 166870 km
    Time Indication: 0
    Freeze Frame:
    RPM: 783 /min
    Load: 19.6 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 9.0°C
    Absolute Pres.: 960.0 mbar
    Voltage: 13.716 V
    001287 - Idle Control System RPM
    P0507 - 001 - Higher than Expected. - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 166872 km
    Time Indication: 0
    Freeze Frame:
    RPM: 938 /min
    Load: 14.1 %
    Speed: 0.0 km/h
    Temperature: 78.0°C
    Temperature: 10.0°C
    Voltage: 13.843 V
    The first happened 2 KM before the 2nd, though they sure seem related don't they?
    I'm looking at these RossTech pages on both:
    http://wiki.ross-tech.com/wiki/index...9/P2187/008583
    http://wiki.ross-tech.com/wiki/index...1/P0507/001287
    I'll test N80 tomorrow, and I believe there are some resistance tests on the MAF in Bentley. What else should I chase?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Lean is not good. Richer is the better of two polars. I'd be ruling out vacuum leaks first. If your n80 was on its way out you'd have a history of persistent evap code. MAF on our cars are pretty robust and you'd get a code there too most likely. I wonder what your fuel trims look like.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by allstock View Post
    Thanks for the response. It’s -3˚ right now, but sooner or later I’ll get up the courage to go sit in the garage with my bare fingers on a keyboard with the car idling and the door open. I might do a 2nd gear WOT graph on it too.
    Feb 24 2004
    Minneapolis
    OK, I'm out of my depth. Started the car, hasn't run for about 14 hours, sat all night in an attached garage with the temp somewhere in the teens. Cold motor at idle, I get no STFT adjustment from Group 33. Are the O2's just too cold to give a reading? Shouldn't they be flipping between rich and lean...constantly? It's not worth attaching a graph, the Lamda in Group 33 stays at 0.0% and does not move.
    Also, I cleared codes yesterday, so the LTFT probably only has about 4 driving cycles on it.
    Mar 19 2014
    That's normal. Lambda control doesn't start registering until the 30-40 Celsius. Voltage is alright. Idle is very high, should be in the decimals near zero below 1.
    Feb 24 2004
    Minneapolis
    Did some testing today. Got it warmed up, did a couple WOT runs in 2nd gear. Both times I saw between 185-190 g/s out of the MAF. So it's probably not the problem. However, at idle these are my fuel trims.
    If I'm reading this right, the LTFT is correcting for a lean condition. Then on top of that, the STFT is also correcting for more lean conditions. Pretty much means an air leak doesn't it?
    So if I spray starter spray all around my motor, I don't see the trim change much unless I completely soak the area circled in red. I mean SOAK! And even then the STFT is only dropping to about -1% with the LTFT up at +6-7%! So either I have a leak in the aftermarket PCV valve there, or in something underneath that isn't affected until it's dripping off the PCV valve. Am I looking at this right?
    EDIT: Oh, and if I wife out the LTFT by clearing codes while the motor is idling, it almost stalls.
    Veteran Member Three Rings saizero's Avatar
    Aug 11 2009
    Chicago
    Check your LPFP duty cycle. If it at 55% or higher, your fuel pump might be on its way out or you need to change fuel filter. Insufficent fuel supply to the HPFP might be the cause of your lean codes.
    Current AWE Boost Gauge : STaSIS catback : 034 HFC : ECS Snub Mount : Upgraded Piston DV : CTS Turbo Catch Can : ER FMIC : DTM Front/Rear Votex Side Skirts : Stasis/Ohlins SL Coilovers
    VAGCOM Owner
    AKA: vmSAi
    Mar 19 2014
    Quote Originally Posted by saizero View Post
    55 percent is actually pretty good and normal. Consistent high seventies and up is an indication the lpfp is on its last leg.
    Aug 11 2009
    Chicago
    Allstock is correct, ideally the closer to 50% at idle the better, but once you're in hit 60 you're in the grey area, and in 70% it's on it's way out.
    VAGCOM Owner
    AKA: vmSAi
    Feb 24 2004
    Minneapolis
    Good idea, here's mine at idle:
    So it's an air leak, not a fuel delivery problem. So I fired up a Hoyo de Monterry Excalibur Classic IV (with the claro wrapper), we all know that's the best kind of leak detector. I can't get anything to suck in smoke, even from a nice cigar like that! But, I sure hear a lot of air moving in that PCV valve. I turn off the engine and for a few seconds after I hear air seeping through that valve. Is it possible to have an internal leak through one of those check valves in there?
    Aug 11 2009
    Chicago
    You could try a finding a leak with a propellant like carb clean, while monitoring your STFT. When it goes rich you've found the leak. Obviously use caution and common sense when using the propellant around a hot engine.
    Sent from my Nexus 5X using Tapatalk
    VAGCOM Owner
    AKA: vmSAi
    Jan 05 2015
    London
    To be honest your fuel trims aren't that bad.
    I have a trim that hovers just above 10% so out of spec and it's a pain trying to diagnose it!
    If your boost vs request, lambda vs request, high pressure vs request and low pressure vs request are fine then maybe best just 'monitored' for now rather than losing too much sleep.
    Are you mapped - 186g/s on MAF is quite high.
    Feb 24 2004
    Minneapolis
    Did that yesterday, and again today. Used starting fluid, and I can make the STFT go leaner when I spray in the area I circled in red above. So today I just gave up and pried that PCV apart. Not sure how this works, but I guarantee you the torn diaphragm isn't doing me any favors. Is that letting boosted air into my intake and making my "lean idle" codes and my "intake air leak" codes too? I'll know tomorrow when I get a new one from the dealer. I glued it back together and screwed it back on.
    That's the Vaico one I saved $15 on 8 months ago. Won't do that again.
    Quote Originally Posted by MrBigglesworth View Post
    But I've been getting a CEL for lean at idle several times now. And now its accompanied by an intake air leak CEL also.
    I thought the same thing, but I'm bone stock in every way. On one of my WOT runs I hit 190 g/s.
    Mar 19 2014
    His stft is high and should be close to zero even on a car with 100k.
    His lambda control is high. The damn ecu is telling him he is running too lean. Do you know what happens to a motor running excessively lean?
    To me that sucks and is lackluster to take the head in the sand approach. Of course it doesn't matter if you don't give crapp.
    His g/s is fine specifically when it was registered while floored - let alone second gear. Third and fourth gear wot is sufficient when logging wot.
    Quote Originally Posted by mtroxel View Post
    You buy shitt - you get shitt more often than not. "OEM" is bullshitt, get the Audi labeled part or make damn sure that the OE manufacturer makes that specific part FOR Audi and save money there.
    Hope your trims drop. Good luck
    Feb 24 2004
    Minneapolis
    Ummmmm...burnt pistons? Yea even with the LTFT pushing things richer, the STFT is still never getting to stoichiometric. Not even close. Something has changed in the last few days, and I'm betting it's that torn diaphragm.
    Every now and then I have to re-learn that one.
    Jan 05 2015
    London
    Have you got a stock air intake?
    If under vacuum your pcv did have a path for excess air flow then then it could suck in air and cause you to go lean at idle.
    Aftermarket consumable parts seem rarely worth the saving in my experience.
    Feb 24 2004
    Minneapolis
    Bone stock. Some of these guys running big turbos might need to find more air. But air intake systems are generally pretty overrated.
    Jan 05 2015
    London
    I am still surprised at your MAF reading - the logs/graphs I have seen for stock 2.0T tend to get to high 150s/low 160s with not a huge difference between 2nd and 3rd gear (around +5g/s).
    It's also interesting that your learned long term values for idle/additive are at c.6%, but you are triggering a fault code which I thought means the fueling adjustment is hitting something like +25%. One thing that could help is if you could capture this on a live data log to find out when exactly and what you were doing when the fueling adjustment jumped that much (logging rpm, throttle, misfires, etc).
    Feb 24 2004
    Minneapolis
    $60 at the dealer and it's good as new. I took apart that bad PCV again and saw what's happening. The back side of that diaphragm is purposely ventilated to the atmosphere. If you trap air there, diaphragm's not going to move. So if there's a cut in the diaphragm, you get outside air. Now my trims look like this:
    STFT toggles between - and +, just like it should.
    Jan 05 2015
    London
    Glad you got yours sorted!
