Results 1 to 27 of 27
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Looks like I'll be changing a big single sooner than I thought.
    Starting today, stay tuned for updates.
    Jul 04 2012
    Woodbridge, VA
    Is that piss in your turbo?
    Nov 02 2014
    Winchester, VA
    Nope, oil to prime it once it's installed.
    Looking for right around the 4 digit mark.
    May 16 2008
    WA
    Holy Guacamole!!! Will it start spooling under 16k RPM?
    Looking forward to some unique goodness
    Aug 24 2014
    Newport Beach, CA
    One thing I haven't seen anything about is why people haven't used Holset turbos when going single turbo. They are stupid cheap, so many sizes, and are proven on many platforms.
    2024 M3 Comp xDrive
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Quote Originally Posted by vavJETTAw36 View Post
    Bahaha that's the same thing I was thinking!
    Looking forward to updates, that's some serious turbo! I've been curious as to the non use of the holsets myself
    2002 Pearl/onyx S4 Avant
    Nov 02 2014
    Winchester, VA
    Aaand, all finished up!
    Man you guys made this not fun, I actually feel bad now. Was hoping to hear some trash talk.
    I was also wrong on the goal, a tad bit over 1200.... And it's not exactly a single setup either. ..
    Nov 02 2014
    Winchester, VA
    And since I've teased you all enough...
    Here's my office:
    And here's the big boy:
    Stock engine with some rods tossed in. 11.25@132mph.
    Jun 10 2010
    How many horsepowers?
    Nov 02 2014
    Winchester, VA
    3600 for the big boy. Each cylinder is roughly 645 cubic inches, and there's 16 of them.
    That 3600 HP is at around 900rpm. Works out to roughly 20,000ft. Lbs. It actually uses a clutched turbo. It's essentially a supercharger until the exhaust gases build enough to unload the gear drive and run as a turbo.
    Also, it's a 2 stroke, diesel, overhead cam with 4 exhaust valves(per cylinder), and a turbo.
    The turbo I replaced today is on a baby v12 4 stroke diesel that's sole purpose is to produce the 480v needed for the comfort systems on our coach cars.
    My username probably makes a little more sense now....
    Nov 02 2012
    Indianapolis, in
    Quote Originally Posted by DieselElectric View Post
    Because racetrain
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    Quote Originally Posted by 88ninety9 View Post
    Because racetrain
    LOL yes!
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    ^^^^^^ HAHAHAHAHAHAHAHA awesome....i figured that from your username.....looks fun...definitely bigger than the turbos i deal with....plus the diesels you fix are a whole lot cooler....
    2008 Ibis RS4....GETing tuned
    Mar 07 2013
    those are some giant oil filters
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by axnjaksn View Post
    Lol you should see the primary engine oil filters.
    10 of those 13 filters standing up are oil filters. You can see the bottom of the housing in the photo.
    The bigger one standing with them is the primary fuel filter.
    All of these get changed every 92 days.
    Jul 20 2014
    San Antonio, TX
    Is it always time based or run time to determine when to change them?
    Nov 02 2014
    Winchester, VA
    Always time based. We are required Federally to perform detailed inspections on that interval, so the manufacturer bases the maintenance intervals as such.
    Aug 04 2013
    Pennsylvania
    Sooo... how do I go from being an auto mechanic to a train fixer?
    I'm like a tree. I'm all root
    Nov 02 2014
    Winchester, VA
    Either know someone, or luck.
    I got in because I happened to update my Career Builder resumer, stating that I was an ASE master certified auto tech, who was looking for a career change.
    Got a phone call asking if I'd be willing to move to VA and work on trains, now they would have to drag me out kicking and screaming.
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Interesting that this shares a similar design to the flow straightener on OE K04 inlet pipes. And yet many aftermarket companies still claim that this feature is "redundant".
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Pics of flow straightener on OE K04 inlets? Why has this not been tested by Jeff?
    I assume the train gig is salary or union hourly. If this is the case it looks awesome and waaaaaaaay cleaner than you would ever expect a train gig to be.
    Nov 02 2014
    Winchester, VA
    No Union, but hourly. And lots of OT for those interested.
    You are correct on clean though. My hands are no longer stained, and my fingernails are cleaner than they ever were wrenching on cars.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Aren't Holset turbos much larger than pte? I would imagine they would be very difficult to fit without chopping the secondary firewall.
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    2016 Stg 2 S6, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    LMAO... I was about to call BS when I saw the water bottle standing upright inside the inlet. Nice one.
    2001 Silver/Black S4, Built engine, Tial 605's @25psi on 93 oct, ET Spec Tune, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
    2016 Silver/Black S6 Sport Package, IE Stg 2 E85 & DSG tunes, IE intake, ARM DP's & Mid-pipes
    Jul 20 2014
    San Antonio, TX
    Sounds like an awesome gig
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    sweet jesus man.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Aug 04 2013
    Pennsylvania
    Sounds awesome. I might have to put my resume up and see what happens lol. I, too, am master certified. Which generally doesn't mean much to other mechanics but it sure makes finding jobs easy lol.
    How does the work compare to cars? Did it take awhile to acclimate or just same ...water, different bucket?
