don't post here often but I feel like it would be good to start up a thread on my swap to keep my thoughts organized. have an 03 allroad with a tip trans that I'll be doing an 01E swap in. Trans slips going into reverse and RPM's hang as I'm accelerating and sometimes slips going into 4th and 5th. Trans swap came from audi4parts.com and is out of a '99 A6. Current plan is to completely pull the motor and trans out of the car so I can replace leaky seals and I think it'll just make the overall swap easier. I have a lift and plenty of tools, so it shouldn't be too big of an issue getting stuff out. I have to wait till spring until the snow leaves northern wisconsin and I can get the mustang out so i dont have to rush through this swap. so hopefully we have a mild winter which so far is what we got.
I have no plans at this point to do a K04 swap or any crazy power upgrades as it's mainly a daily driver and I have my mustang if I really wanted to have some fun. plus its way cheaper and easier to replace stuff hah.
This is what i'm working with.
i have no idea how the shifter stuff goes together, and I think im actually missing a cup and a bushing or two. not entirely sure
Right now this is the list of things I still need to buy/order before I tear the car apart.
Flywheel bolts
pressure plate bolts
clutch disc
wheel bearing
pinch bolts
trans fluid
brake fluid
front brakes
rear brakes
valve cover gasket
cam seals
throwout bearing
pilot bearing
alignment sleeves
SAI blockoff plates
starter
alternator
spider hose
motor mounts
turbo gaskets
hollow out down pipes
flush heater core
anything else I should look at replacing while its out?
These are a couple links I'll be relying on while doing this swap to make sure I get everything I need as I don't think the swap kit came with everything, but some of it should just be replaced for maintenance reasons anyways.
http://www.audizine.com/forum/showth...-Bigger-Badder
haha, the fricking pinch bolt... i need to replace a wheel bearing so im going to pull both pinch bolts on both sides and it'll just make things easier with the axles, and any fixes in the future as i dont think theyve ever been removed
http://www.passatworld.com/forums/b5...easy-pics.html
01E parts swap thread
http://www.audizine.com/forum/showth...p-parts-thread
random thread 01e swap
http://www.audiforum.ca/a6-s6-rs6-71...wap-diy-59468/
and the random slight set back one afternoon
