WTT: 2003 20th Anniversary GTI, Imola yellow for your AWD Audi
Hello everyone!
I'm looking to sell or trade my 20th AE Imola Yellow GTI. Cash price is 6k$ obo.
I'm looking to trade for anything awd, but im open to all trades. It must be manual or DSG, and must be daily driver ready and reliable. I have spent the money on this car to insure that, and this includes having a good set of reputable tires.
Located in wilmington, NC.
2003 20th AE Imola Yellow GTI #2465
169k
Mods:
3" catless ghl downpipe to 2.5" straight pipe
Short ram intake
Forge 007 dv
Stage 2 tuning by reflect running
2-step + no lift shift
Hitachi coil packs
034 Motorsports silicon pcv line kit
034 Motorsports SAI block off plate (sai deleted)
Eurojet FMIC
N112/N249 solenoids deleted
Ecs 5mm front wheel spacers
Raceland coilovers (not blown)
Front ECS slotted rotors
EBC red stuff front pads
Drivers side Raxle
New South Performance boost gauge
Chrome trim euro switch
Maintenance:
When I bought the car a few months ago, the motor had some oil leaks from the ghetto rigged pcv system and the entire motor/engine bay was so gross you could barely see screw heads. My shop decided to pull the motor completely and we degreased/pressure washed the engine and engine bay.
Brand new k03s turbo, maybe 2.5k on it now
The entire front suspension was replaced with an ECS stage 3 front suspension refresh kit.
New thermostat, coolant flange, coolant reservoir
New O-rings in the clutch bleeder valve.
New fuel filter
New e-brake cables
Timing Belt/water pump replaced at around 140k
Clutch and forks replaced around 155k
4 nearly brand new Nitto Neogen tires
Freshly aligned
All maintenance performed/installed by ??Audub Motorsport? in Wilmington, NC
The bad:
Front lip has two small cracks that are almost unnoticeable, and are easily fixable. Front bumper/hood needs a respray due to clear peeling.
All 4 interior door cards need to be re-wrapped. I plan on doing this one weekend, but it's not a big deal to me. Can also buy leather door cards for about 250$
The front drivers side wheel speed sensor is bad. I'll replace this before I sell the car, or give cash to the new owner depending on the trade.
Air conditioning needs a charge.
The good:
The headliner is original and perfect
The recaros are near perfect. No rips or tears, all handles in place, just need a good cleaning.
The car runs perfectly. It pulls very strong for a 1.8T, holding 22 psi.
The car is very dirty in the pictures, so if you would like better pictures, just ask.
List Date: 1/15/2016
For more info, click here to view the original listing: WTT: 2003 20th Anniversary GTI, Imola yellow for your AWD Audi
This item is no longer available.
