Results 1 to 16 of 16
    Dec 22 2015
    2008 S4
    Michigan
    Post Just got my S4 and my first problem came already
    So I just picked up my 08 s4 yesterday and on the way home the passenger side headlight went out. I turn the switch off and on then the headlight went on for about 1 second then goes out again. I did it again when i got home it would turned on and then goes out. what seems to be the problem? Light bulb or ballast? I have zero to little mechanic experience so bare with me please.
    May 16 2008
    WA
    you could switch bulbs from side to side to know for certain.
    The S4 knows when you are in a state of vulnerability, and then it pounces lol
    I had a spare bulb from another project, so I replaced one headlight bulb to restore performance, and the very same night... the other one burns out... they know...
    HID bulbs lose lumen output over time, so its not a bad idea to toss new bulbs in there anyway, especially if you suspect they are the originals
    Established Member Two Rings S42RS4's Avatar
    Mar 16 2015
    Tacoma, Wa
    Quote Originally Posted by getslideways View Post
    As what getslideways says or you may need a new ballast. If you gonna replace the lights, I replace the ballast also.
    2008 What can I say, I had to get another RS. Jackal Tune, Gruppe M Intake, Escort IXc, Euro Seats, Euro Steering Wheel, JHM Intake Spacers, Custom 2.5 exhaust w/x-pipe, JHM SS Lines & more to come
    2007 (Lacy)The Trouble Maker Traded in.
    2006 Traded In
    Dec 22 2015
    2008 S4
    Michigan
    So I probably might as well throw a aftermarket headlight in then
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    angel eyes, those are always a hoot for aesthetic purposes
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Only downside with b7 is you have to remove the bumper for headlight -- please don throw a aftermarket headlight in...
    oh stop it-- how's your search going?
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    Quote Originally Posted by Blackstallion View Post
    Big 2nd.
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    What's the error message? Dipped headlight? I get one of those every 18 months due to the streets in my city.
    Also, when I first bought my S4, it was from an independent dealership (not Audi) and it came with a 30 day warranty. I got them to pay for the first ballast replacement. Did you buy it from a private sale or through a dealer of some sort?
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    I would try replacing both bulbs. If it works, keep them in. If not, return them.
    If that doesn't work. It's probably a ballast issue.
    Dec 22 2015
    2008 S4
    Michigan
    Quote Originally Posted by Axel- View Post
    ya the errror message is dipped headlight.
    - - - Updated - - -
    Quote Originally Posted by TEB View Post
    Big 2nd.
    are they that bad? i think they look quite good actually.
    Nov 11 2010
    Rochester, MN
    Quote Originally Posted by audidd777 View Post
    Probably not, but a lot of guys don't like to see someone turn their beautiful B6/B7 S4 into something that it's not...like a BMW with Angel Eyes.
    Ultimately, it's your car and your money. Don't worry about what people think of your new head lamps.... Unless they're angel eyes. Then you should be ashamed of yourself.
    19" B8 S5 Peelers
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    I like Angel Eyes, but i can't find Angel eyes with HID for our S4, anyone found one yet?
    B6 Noggy Avant, B8.5 Allroad
    Sep 19 2010
    Non-OEM lights (head or tails) are just a personal pet peeve of mine. I particularly don't like putting a trademark BMW look on Audis. Just trying to do my part to keep the brand unique and classy ;)
    Dec 02 2007
    DC/MD/(VA)
    I've stopped searching; currently just toying with the idea of an e90 ///M or leasing an F80 ///M
    2015 B8 SQ5
    Click Here
    Past
    Nov 12 2015
    Oregon
    As previously stated, just loosen the bumper (depending on the model it should only be like 15 bolt/screws and only takes like 10 minutes) then loosen the headlights ( 3 screws if i remember correctly, one being a PITA to get to unless you have a long torx screwdriver and/or bit..or a long flathead screwdriver that will fit snug into the torx head. you can try the flathead on one of the other torx bolts with the same size head to save you the time and hassle of trying to see if it fits deep down in the hole) take your bulbs and swap them from one side to the other. I don't think this will fix a "dipped" headlight code, but it will tell you definitively if the problem is a bulb or a ballast or other problem. Hope this helps you. I had the SAME EXACT situation as you(minus the code) on the day i bought my S4. Worked for me!
    My build log
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    If you buy a BMW i will hurt you
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
