Results 1 to 9 of 9
    Mar 01 2006
    2017 Q7
    Melrose, MA
    Sirius disapeared after body work
    Car was in the shop for a new front bumper, and driver side door repair. When I got it back the radio and other other electronics work fine but there is no more Sirius option from the tuner menu. I've read that some others have lost Sirius and needed and MMI software update to get it back. I'm not sure if I need to go this route or if something could have happened when the car was in the body shop. When I connect VCDS and try to talk to the Sat Radio it can't connect. The car is going back to the body shop to see if they might have somehow disconnected power to the Sirius receiver. Where does the power wire to the Sirius receiver come from? Is the Sirius receiver behind the center console? Any thoughts?
    2020 M4 Convertible 6MT - Alpine White - Sakir Orange - JB1
    2019 X3 M40i - Dark Graphite Metallic
    2010 S4 - 6MT - Phantom Black - Black/Black Alcantara - Nav - Sports Diff - G.I.A.C. Stage 2 - AWE S-Flo Intake - 034 Transmission Mount Insert - JHM Crank Pulley - CR-15 Strut Tower Brace – Sachs XTend Clutch
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Ray Khan View Post
    You might see if they stole your receiver, lol.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Mar 01 2006
    2017 Q7
    Melrose, MA
    Quote Originally Posted by JDillon15 View Post
    haha...fortunately it's not a shady shop.
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    sure it's not just the sat antenna that was disco'd?
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    Mar 01 2006
    2017 Q7
    Melrose, MA
    Quote Originally Posted by s4buckeye View Post
    Not sure but if the antenna was disconnected wouldn't there still be a Sirius option in the MMI tuner? I'd imagine there would be no reception but at least the Sirius option would be there. I went back to the body shop today and they took a quick look at it and couldn't figure it out. It doesn't seem likely that the antenna was disconnected based on the work that was done.
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    No, if the antenna is disconnected it'll become greyed out and inaccessible (on my 2011 MMI 3G). There are individual leads for sirius + nav.
    I believe on the s4 the leads are long and run down to the receiver directly, so should be a quick check for you. Look for red/green/blue circular coax connectors.
    Dec 21 2008
    Kali
    i dunno. On my B7 I thought the antenna hookup had some sort power aspect to it. if so, maybe it would not show in the MMI if the contact was not being made on the hookup.
    Mar 01 2006
    2017 Q7
    Melrose, MA
    Quote Originally Posted by yakev724 View Post
    Interesting...Where would I look for those leads? Are those leads running from the box behind the left side liner in the trunk?
    Jun 26 2014
    Brooklyn
    Based on lead length, I believe it's by the sirius receiver, next to the amp on the left side of the trunk, behind the protective covers. (Not guaranteed)
    Sorry I can't give a definitive answer, I have a Q5. (Recently had to replace my antenna and ended up using one from an a4)
