Results 1 to 16 of 16
    Veteran Member Four Rings B8 S FOR's Avatar
    Feb 15 2011
    Pittsburgh, PA
    Brake Squeal!!! TSB Warranty - Need Ammo for AOA
    Hi guys / gals....under 40 degrees my front brakes are squealing like pigs coming to a stop. Had them checked at the stealer front pads at 10/32...like new pretty much. Stealer said too bad basically shit happens.....My car has 15K on it. Called AOA and they said my brakes are under 13mm so the TSB fix doesn't apply to me ? ? ? Being real Ass Hats! My car sounds like a old Buick sled and I want to crawl under my seat coming up to a light. Can you guys add any insight or ammo for me? I have researched and others have had theirs replaced under the TSB with my same mileage or more. They are saying I am under 13mm on the pads so tough shitski!
    AUDI 4 LIFE.........B9 S5 Cab Prestige/ Mythos Blk Met
    Gone but not forgotten:
    2015 B8.5 S5 Cab
    2011 B8 S4
    Senior Member Three Rings wildtouch83's Avatar
    Mar 04 2013
    United States
    first off, greetings to another western Pennsylvanian! Which stealer did you go to? Audi Pittsburgh or Sewickley?
    Does this squeal occur at lighter pedal pressure? While you're stopping, if you suddenly applied increasing brake pedal does it go away?
    2018 Nardo Gray TT RS - SOLD
    2018 Manhattan Gray Q5
    2006 A4 Avant - RIP
    2013 Phantom Black RS5 - SOLD
    Feb 15 2011
    Pittsburgh, PA
    Sewickley. Any pressure ...below 40 degrees it sounds like a train! AOA looked into it and was like you are below 13mm on your pads so tough shit! Not acceptable! Owned many Audis ...my 2011 S4 never had an issue. Problem is...last year I didn't drive my Cab in the winter ...it sat so never really dealt with the squeal...it was here and there but now that I am DD it ITS DRIVING ME NUTS!!!! Thanks!
    2015 B8.5 S5 Cab
    2011 B8 S4
    Jan 07 2011
    2013 C300 4Matic
    this issue has been there since 2009 ( had it on my s5 ) and even today. I doubt they will "fix" it. I believe its the pads they use. my old infiniti did the same exact thing.
    switching to aftermarket pads fixes the issue
    FWIW I never had this issue on my a5
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Apr 11 2013
    '14 Misano Red RS5
    Minnesota USA
    For reference, I have never had any squeal....even @ -40f. My steering rack failed at -40, but the brakes were fine.
    Senior Member Two Rings sm1287's Avatar
    Feb 15 2015
    2017 Toyota Camry, 2018 Audi A5 Sportback
    Dallas, TX
    I have the same issue, had it checked at my first maintenance and they said to just hit the brakes hard to get that layer off...that didn't fix it. I get a set of pads free b/c of my warranty but I'm not for sure if I should stick to those or go aftermarket (when I do need to change). I absolutely hate the squeal, it's embarrassing.
    Mar 05 2014
    SF Bay Area
    at 15k. why don't you just change the pads to a different brand.
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Brake Squeal!!! TSB Warrantly - Need Ammo for AOA
    Have the same squeal on my '10 A4 Avant. Only in cold weather and received the same "solution" from the dealer, brake hard and it will go away. It doesn't, ever. After market pads are likely the solution as others have said.
    My A5 never had this issue when I was winter driving it
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Jan 18 2010
    Columbia, SC
    I have some squeeling on my 2013 A5 when its cold and they don't do it all the time. I have about 1,300 miles until the 35,000 mile service and I was just going to wait until then as they usually check the brake pads as part of the service.
    Feb 15 2011
    Pittsburgh, PA
    Quote Originally Posted by Scumbucket View Post
    Because the front pads are at 10/32. There is a TSB out there on this and Audi has covered people with this issue even over 15K.
    2015 B8.5 S5 Cab
    2011 B8 S4
    Established Member Two Rings Lindsaaay's Avatar
    Jan 21 2016
    BKYLN
    My car does the same thing. I bought it in Florida a few days ago and while we were down there I didn't hear a thing. Once we got back up to New York the brakes squeal like crazy at times. Major difference in temperature obviously.
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Upgrade the pads. Stock pads are no good. It's a proven issue.
    Mar 11 2012
    Audi A5
    Ventura, CA
    I have this problem as well in my '11 A5. But only when the brakes are cold. As soon as they warm up, no more squeal.
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Are you guys doing a lot of city driving, stop start, light braking?
    Feb 15 2011
    Pittsburgh, PA
    I went out to a fairly large parking lot got it up to 100 and slammed the brakes. Still squealing when temp is under 30 degrees or so. when it gets warmer there is no squeal. No other car I have owned has done this in cold weather including my 2011 S4. I drive highway and city and brake hard.
    2015 B8.5 S5 Cab
    2011 B8 S4
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Quote Originally Posted by B8 S FOR View Post
    Definitely try another a more controlled bedding than that. Three or four back to back very hard 60-5mph semi-stops then drive around to cool right down with as little braking as possible. Hopefully that would get glaze off and add a coating of fresh pad material to the rotor. They are so soft to avoid any noise I'm surprised this happens. I already swapped my RS pads out long ago so can't relate.
