Results 1 to 6 of 6
    Aug 10 2015
    965 | X351
    Chicago
    Auxiliary Coolant Pump Carnage
    The bitterly cold weather the last few days exacerbated the slow leak from my Auxiliary Coolant Pump so with the near 50 degree temps today, I did the bypass to get me through the next couple of weeks before I do tb service, water pump, vc gaskets, etc. Note to all...it's not fun when the pump explodes...people will point and stare when you have a cloud of burning coolant following you.
    2tripnaught with a little of this and a smidge of that, although normally idle.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Yup winter just took mine out too, same thing. Will be getting another one before summer arrives.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jul 04 2012
    Woodbridge, VA
    Procrastinating usually ends up biting you in the ass. I know because I get my ass bitten all the time!
    Jul 20 2011
    Providence - RI
    I deleted mine....
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    If you think that's embarrassing just wait until you pop a turbo or two!
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    It's just as bad when you're still blowing smoke even after changing the dead turbos because there's leftover oil in you exhaust.....
