Give me some ideas! i was on my way home from work and stopped at an intersection my car just turned off as i was about to pull off. And it will not start for ANYTHING. I have VAGCOM and scans didnt show anything other than my exhaust temp sensors failing which Ive seen since i bought the car last year. Its a 2003 A6 2.7T 6MT. Car is flashed with GIAC. Other than having to replace the battery and alternator over the summer and just today my control arm kit came in from ECS, the car hasnt given me many issues. The spark plugs are all new, gapped at .028 i think it was, and the coils are being replaced as they die, 6, 5, and 1 so far. The ABS Control Module was sent out for repair and came back working! ESP and ABS work fine. Always fed it 93 from BP, oil changed every 4k with Castrol 0W-40. I just did and drivers side valve cover gasket replacement right before an oil change. PCV hose replacement was done months ago. Coolant flush just done and still trying to get air out of the heater core, think its about done heat is on and hot. Timing belt was done at 90K by the dealer, its at 148K now.
The car was about to run low on gas and i was on my way to the gas station. I didnt get the low gas alert yet, but i wasn't far. Thought it ran dry and i rolled it to the gas station and gave it 4 gallons but nothing. Ive been reading around and some people suggest the cam position sensor, Coolant Temp sensor, Fuel Pump relays, fuel pump fuses, the fuel pump. Im not sure where to start. I have a Bentley Manual and feel somewhat comfortable attacking this, i just dont want to spend too much money taking guesses at what it could be. How do i trouble shoot this? Thanks in advance.
