Results 1 to 17 of 17
Thread: A few questions
    Jan 07 2016
    Upstate NY
    A few questions
    I have a 98 a4 1.8TQM, I am looking to cross the 300hp threshold, Can anyone post a link on a recommended build? I would like to run the K04 turbo instead of dropping the money on a garrett since this will be mostly a winter car/ back up car for when my DSM decides to die again. I have a 105 miles round trip commute so i would like to be conservative with gas consumption and reliability. Any help with be awesome.
    Also my trunk decided to work just fine for a week or so then one day went to open it and all it does is push in. If i put the key in it and push it in and turn to the right it locks and do the same but turn to the left it unlocks, just doesn't open. Any idea?
    Anybody know what the max tire size/ rim size combo i could use without throwing my speedo off? I live in a rural area and the cops can be real assholes so I watch my speedo constantly when driving around my town.
    Has anybody punched out their cat and run the spark plug non foulers to trick the computer into thinking there is a cat? I live in Upstate ny and emission laws are strict, I heard from a friend of mine that you can do that to keep a check engine light off.
    If anybody can answer my questions that would be great, Thanks in advance.....
    - - - Updated - - -
    Sorry for the misspelling, I should of previewed first :)
    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    You wont reach the 300hp mark with a K04 or even Frankenturbo upgrade. I believe its highly possible with an eliminator setup.
    The tire size, I would find a tire calculator online, enter in your stock size, and play around with another size to get it as close as possible.
    Ive got a 98 as well with no cat, and I had no o2 fault using 2 o2 spacers for the pre cat sensor. I later removed the sensor so I could run an Innovate Wideband since I didnt have a 3rd bung in the exhaust.
    All of these could have really been answered with a bit of searching, but I was bored and decided to help out.
    1998.5 A4 1.8TQM My Build
    Dec 29 2015
    B5 S4
    Illinois
    Stock - 205/55 R16
    225/45R17 +1.06%
    225/40R18 +2.35%
    Jan 07 2016
    Upstate NY
    Thanks CoyneJ
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Most fun for few bucks go Franken turbo, as said before but will not net 300+. But still puts a smile on your face and drives close to stock but much better power. I have a build in my sign, of a elim 2860. That's the smaller side of BTs that sees just over 300 when set up right. Do some research lots of good info here and we will answer questions the best we can.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    SOLD the GOINHAM A4 ---> GT2860 Project
    Dec 29 2015
    B5 S4
    Illinois
    http://www.audiforums.com/forum/b5-m...rmation-93439/
    really great threat to find the right turbo for you! + most info you need to install it
    Nov 17 2011
    Fredneck Maryland
    This is from our B6 friends but numbers and specs are almost the same. Other tuning options for everything else should be the same.
    -K04-GT2X-GT28r-GTRS-GT28rs-Official-Turbo-Comparison
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Someday GT2871r.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Nov 17 2011
    Fredneck Maryland
    Quote Originally Posted by King_ View Post
    Someday GT2871r.
    Unless you get a deal just go gtx still need rods for both. I got a super deal on my 2860 that's why I went Elim other wise would have went full frame gtx or efr
    Sent from my SM-T560NU using Tapatalk
    Oct 09 2012
    Quote Originally Posted by GOODBYNAAIR View Post
    Not doing rods with a gt2871r elim.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Nov 17 2011
    Fredneck Maryland
    You will only see 80% "safe" with out running risk of windows in the block.....Be sure to get a good tune.
    Edit
    I don't want to jack his thread we should move conversation to ur build or ibs. Just saying.
    Oct 09 2012
    Edit
    It'll probably be fine at 100%. I will find out someday.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jan 07 2016
    Upstate NY
    Thanks everyone, My plan for the summer is rebuilding the trans, swap the clutch and flywheel. The start on the motor, crank, rods, pistons, valve work etc. From then on ill be looking into turbos...... To hold me over has anybody punched their cat out and ran the spark plug non foulers?
    Dec 29 2015
    B5 S4
    Illinois
    i cut my cats out because i had exhoust leak and replaced it with a straight pipe but i have not got spacers yet
    Jan 07 2016
    Upstate NY
    Here in NY that will fail it when they look and see just a test pipe
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
