Results 1 to 14 of 14
    Junior Member Two Rings iwerk's Avatar
    Jan 14 2016
    Illinois
    Tail-light led burned out on cluster
    Hello,
    My name is David and I have noticed this last week and was wondering if any of you have seen or fixed this issue. I have a B8 S4 and one of my LED's on the tail light cluster burned out (please see image below). Please let me know if there is any way to replace or fix this issue. My OCD is kicking in and it is really bugging me lol. Thanks in advance!
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    I think the whole Unit has to be swapped out...maybe someone can prove me wrong
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Established Member Two Rings peekaBu's Avatar
    Sep 18 2013
    Mercedes C300
    New York City
    From my experience, only way to fix is to replace the whole thing. Dealers will replace if you have warranty.
    Otherwise. I would suggest ordering one and replacing it yourself
    Jan 14 2016
    Illinois
    So Im guessing ECS is the way to go for a new inner unit?
    Jul 24 2015
    Quote Originally Posted by iwerk View Post
    http://genuineaudiparts.com/parts/20...&siteid=214407
    I believe that is the part, just check to make sure.
    Jan 14 2016
    Illinois
    Quote Originally Posted by justr0 View Post
    I gotcha boss. ECS is selling them cheap for $250 so i'll look into this further. Thanks for your help!
    Mar 01 2006
    Kitchener, ON
    You need to replace the whole unit, I had the same issue a few months ago...
    I know a guy in Latvia that will hook you up for cheap, only took a week to get here :) Honestly, the new one had better fitment then the original, go figure.
    Make sure you get the left side not the right side...
    http://www.ebay.com/itm/AUDI-A4-S4-B...sAAOSwPhdU7G4Z
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    Yep. Replace. I had two burned out on my right side. I found a used one on eBay however for $80 or $90. So far so good.
    Sep 28 2013
    B8S4, C300 4matic, Honda CR-V
    It's pretty common. I had 2 bulbs out on left inner. Mine had defective seal. It was going out every time I washed my car or I drove/park in heavy rain then come back on when it's dried up enough.
    I had AoA cover 100% of the cost.
    interior and license plate LED lights, E-code headlights with 6000k bulbs, AWE catback, H&R OE springs, APR Stage 2, 19" BBS RGR (summer), stock 18" with 15mm and 20mm spacers (winter), carbonio intake, lots of VAG mods, 35% tints all around, lots of road rash, 034 transmission mount insert, SPC ACS, Spulen rear diff mount, Bilstein sport shocks, CR-15 strut brace bar
    Oct 31 2013
    Morris County, NJ
    Try spraying the electrical connector on the wire with deoxit. It's worth the $13 before moving on to a replacement light. I had a few lights intermittently go out on my mdx and the spray worked.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by mmm def View Post
    +1 actually forgot about this already...
    I did this and got one bulb to come on, but it would go out again shortly after so I just said screw it. Definitely worth a try, depends on how bad the situation is but worth the couple $$ for a quick fix
    Past
    Feb 20 2006
    NC
    I doubt the LEDs are going bad, usually it is the connections. I had the LED go out on my wife's Mercedes mirror, turned out the wire had cracked.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Jan 14 2016
    Illinois
    Last weekend I sprayed the connector with WD-40 and the light came back on!
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    The whole unit needs to be replaced...happened to mine. they told me though that there is a TSB for them both because the seals on there lets moisture in. might want to bring it in and have them replaced should be covered under warranty
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
