Originally Posted by
STA4
Thanks. I just dropped by Audi and the tech told me that the A4 uses a 4 link front suspension with fixed struts and that there are 4 ball joints. He said that they can make this noise when they go.
The B8 chassis Audi does use a 4 link suspension which has 4 ball joints. 3 of which are on the end of control arms (2 upper and 1 lower) and the 4th being the tie rod end.
Not saying it's not a ball joint but there can be other possibilities. I see in your signature that you have stasis springs. At one point your suspension was all removed to install these. If the control arms were not preloaded to the proper ride height at installation there's a possibility it could cause premature wear to the bushings. Also the strut mount bushing could have gotten damaged or not seated properly and over time caused wear which could lead to a squeak.
Definitely have a certified tech go over your suspension for proper diagnosis.
Jason
