Results 1 to 8 of 8
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    BW K03 and K04 Turbo's
    I have a k03 turbo from a parts car with 100k miles on it. Has some minor shaft play. $200
    Also have a K04 that only has 25k miles on it and was swapped when I went to a FT F21L mixed flow. It has NO shaft play and is in excellent condition. $450
    Also have an O.ct aluminum TIP for the K04 and UM programmed ECU for TT 386 injectors w/k04.
    Will post some pics when I get home.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Aug 21 2009
    Bump
    Oct 24 2013
    girls MK4 1.8t
    United States
    Quote Originally Posted by DiertyEuroSpec View Post
    What caused the damage to compressor wheel?
    Stupid drift A4
    R.I.P RWD-converted '99 A4 Avant 1.8T
    Aug 21 2009
    One fin is slightly bent and pic exaggerates it. Hardly a damaged compressor wheel?? Obvious it was some sort of FOD. Must have been quite small.
    Sent from my LGL33L using Tapatalk
    Feb 23 2015
    Middle GA
    How much for the ECU?
    Deactivated Three Rings
    Nov 18 2016
    Tokyo japan
    Is there a picture? Bork warner shaft has no play. PayPal payment to Japan. Please reply to my e-mail. [email protected]
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    Quote Originally Posted by garytightpants View Post
    Is the K04 the one with the damaged compressor wheel?
    Lol that things donezo'd.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Active Member Two Rings GTFORZA's Avatar
    Jul 16 2017
    67 Datsun 520, 1973 Beetle, MK! Jetts Turbo Diesel, MK2 Jetta
    Birmingham AL
    Part with the inlet pipe?
    Sent from my Pixel using Audizine mobile app
    2001 Audi A4 1.8t quattro sport package - Custom CAI, Eurodyne Maestro, Turbosmart DV, Down Pipe
    1987 VW Jetta 1.8 Base model with over 300k miles
    1984 VW Jetta Turbo Diesel GL - hand built injection pump and pushing 30 PSI
