    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    BW K03 and K04 Turbo's
    I have a k03 turbo from a parts car with 100k miles on it. Has some minor shaft play. $200
    Also have a K04 that only has 25k miles on it and was swapped when I went to a FT F21L mixed flow. It has NO shaft play and is in excellent condition. $450
    Will post some pics when I get home.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Aug 21 2009
    Bump
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by DiertyEuroSpec View Post
    Bump
    Are those pics the k04 or the k03? I could be interested in the k04
    Aug 21 2009
    K04 pics
    Established Member Two Rings Digitaldub's Avatar
    Apr 29 2010
    Toronto, Ontario, Canada
    K04 pics
    Are you able to post more pics of the K04-015 compressor housing? I would like to validate that there is no cracking anywhere on the compressor side of the turbo. Also do you have proof of purchase? where was the unit purchased from?
    Interested if it genuinely only has 25K miles of use.
    thanks,
