Thread: New ride.
    Senior Member Two Rings Detroitfire23's Avatar
    Mar 08 2012
    '92 Ford Mustang twin turbo
    Clinton Twp MI
    New ride.
    I just picked my second Audi, a 2005.5 B7 2.0T Quattro 6 speed manual in black. The car has just over 100k & has had all work and synthetic oil changes done at the dealer. The HPFP and cam follower have been done, and the diverter valve has been replaced which seems to have been a problem for these cars, but is it something I'll have to worry about again, or did the dealership put better parts in?
    I really like the car so far & only plan on doing minor mods like a test pipe, bigger brakes, a catch can setup and some new wheels
    Any other info u guys can help me out with would be much appreciated! Mike
    Veteran Member Three Rings mannyjfk's Avatar
    Dec 17 2010
    Mercedes Benz C Class
    Jersey City NJ
    You may have to do the timing belt and water pump. B6 requires it by 80k but not sure on B7. Worth investigating.
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    B7 requires every 60k Km in Australia.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Active Member Two Rings Midwest Playa's Avatar
    Feb 04 2016
    Kansas City
    Are you serious? 60 km for a timing belt? that does not sound right.
    Midwest Playa
    Audi A4 B7 Cabriolet
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    New ride.
    Quote Originally Posted by Detroitfire23 View Post
    Cam follower is an ongoing issue. It is super easy to replace yourself and i did mine every 10k because I'm a nut, but every 20-30k to be on the safe side. http://freepdfhosting.com/8791e81dac.pdf.
    If the diverter valve was replaced with the revision you dont have to worry about that anymore, I revised mine and run more than 20psi no problem. Test pipe and a tune is the way to go. 034 Motorsports fits beautiful for 158$.
