Results 1 to 9 of 9
    Jun 29 2015
    Danbury, CT
    Front & Rear Spacer Sizes to make Stock Rims Flush
    Anyone know the spacer sizes I should order to make my Stock Rims on Stock Ride Height flush?
    Jul 04 2012
    Woodbridge, VA
    You could probably put level to the fender and the ground and then measure between the wheel lip and the level. Convert that to metric MM and you got yourself some measurements to go by. You'll have to do this for the front and the rear since the distance between the fender and the hub is different
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    If you're planning on keeping the ride height stock, you'll be safe running 20mm without rubbing issues. If you want a "truly" flush look, 25mm but you will rub.
    Word of advice, get hub-centric spacers.
    May 16 2008
    WA
    Here is my old setup, maybe it will help in some way
    GTF ~25"
    225 tires
    Stock 17" wheels
    15mm Spacers rear 10mm front
    No Rubbing
    2.5" Wheel Stud Conversion
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by zcspec View Post
    +1 on the hub centric advice. If you don't, you'll be vibrating.
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by getslideways View Post
    GTF ~25"
    225 tires
    Stock 17" wheels
    No Rubbing
    What brand/Kit did you go with? I'm looking at ECS right now and they have spacers with the Ball Seat Bolts and Conical Seat Bolts. Any Difference? Also, would these be considered Hub Centric?
    For example
    https://www.ecstuning.com/Audi-B5_S4...cers/ES250727/
    Thank you!
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by amusante View Post
    For example
    Thank you!
    Those ARE hubcentric. See they have that lip your wheel hooks onto? its the same lip on your hub. For ball vs conical, it depends on your wheel. General rule is OEM=Ball. Aftermarket wheels are usually Conical.
    Mar 22 2013
    AK
    I have a set of (4)original hubcentric 15 mm MTM spacers with lug bolts, looks great with stock rims, with very small usage and never seen snow or salt. PM me if interested .
    May 16 2008
    WA
    The ones I had on in that pic were H&R hubcentric for the front 10mm set and the rears were NON-hubcentric generic dual pattern 15mm. Never had any issues with vibrations despite the rear not being hubcentric. Although to be fair getting things center and happy is much easier with studs vs wheel bolts.
    Hubcentric do make installs easier and less likely to vibrate, but its not impossible without them. Plenty of my old mopars never had hubcentric wheels or spacers, and were never an issue. I usually get everything just about snug then give the wheel a good spin and tighten simultaneously. Its been working for me but maybe I am just on a string of good luck.
