Hi fellow members. Unfortunately I am not able to communicate with VCDS cable in my Audi A4 1.8TQ B6. This came up (I cannot put my hand to fire...) after a re-connection I did near RNS-E calbling introducing a BOSE audio system. The VCDS cable in TEST reported back that communication is questionable, K1 Line OK, K2 Line short to ground! I checked cable in another car and it is working perfect! To be sure about, I visited a local repair shop and ussing original VAS and an aftermarket Delphi diagnostic system, they managed to communicate with bus but not with Xenon and Navigation modules. All other modules replied and communicated with no problem. Have you any idea how I can check cabling or how to remove one by one connectors of these modules in order to determine where is the fault? Is this fault happened to anyone of you before? I double check RNSE cable connections (that was my last intervention) and I didn't found any fault. Also looking at CAN Bus drawings (by ELSA) I realized that there are three communication circuits under CAN name, Connection CAN (I assume the power-engine one), Convenience CAN and Infotainment CAN, All start from dash panel and according to diagrams are independent. Somewhere also a Navigation CAN appears but it is not routed from dash panel.
Thanks in advnace for your kind attention.
Regards,
John
