Results 1 to 24 of 24
    Jan 14 2016
    H&R Street Coliovers
    Have S4 (B8), put H&R sport springs on. Lowered me too much, scraping belly terribly when entering office garage. Need to get closer to stock, but want tighter suspension (for street us only). Figure choice is either H&R OE sport springs (mediocre solution) or H&R Street Coilovers. H&R coilovers list the lowering from 1.0-2.2in and the OE sport springs list the average lowering of 1.2in. With the coilovers I'm hoping I could get similar height to OE springs or even closer to stock with the and the benefit of a street performance coilover, plus a reasonable price (about half the cost of the bilsteins).
    Talking to those in the know, reading various forums. H&R street coilovers getting good reviews, but one person suggested the lowering is more aggressive than advertised.
    Would be grateful for any feedback, especially re: lowering as I would need to keep them at highest setting. want to make sure not too much below stock and not too bouncy at that setting (certainly hoping tighter than stock).
    Thank you.
    May 17 2012
    Houston, TX
    I've already read that the H&R coilovers are low. if you don't need coilovers specifically for track or sim then I'd just go OE springs and upgrade shocks now or later. OE is the perfect drop IMO.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Get Eibach Pro Kit springs and run them with your stock shocks or with Bilstein Sport Shocks.
    Stage 1 more than you RS3
    Oct 14 2012
    Empty...for now...
    SE PA
    I probably sound like a broken record by now, but it's particularly relevant here: I have the H&R Street Performance coilovers on my B8.5 and the rears are set as high as I can get them. There is maybe ~1-1.5 threads remaining before the collar reaches the end of the thread, which is as close as I care to go. (It's a fine thread so that extra full turn won't get it much higher). Then the fronts are set to match the fender-tire gap of the rear, although the fronts do have a good bit of upward adjustment remaining. (You could leave the rear where it is and raise the front higher, but it won't look right). If you need your ride height higher than this, then do not get the H&R Street Performance coilovers:
    SOLD 2015 Daytona Gray S4
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Bilstein suspension on these cars are known for not being as "out of the box low". But The suggestions made by these two gentleman are solid advice. The Bilstein Shock and OE sport spring might be a very good option for you
    You can see the OE sport spring on our website here
    http://vag.excelerateperformance.com.../i-539936.aspx
    Or the Bilstein /Eibach pro kit (B12) combination
    http://vag.excelerateperformance.com...i-1735908.aspx
    Jun 19 2014
    toronto
    Based on your criteria, the bilstein b12 prokit would be a great choice, as would be rs5 suspension. Fwiw i run rs5 springs and shocks, got a mild drop and a big change in handling. Drop is approx half an inch on rs5 setup
    Jan 14 2016
    [QUOTE=SteveYem;11326442]I probably sound like a broken record by now, but it's particularly relevant here: I have the H&R Street Performance coilovers on my B8.5 and the rears are set as high as I can get them. There is maybe ~1-1.5 threads remaining before the collar reaches the end of the thread, which is as close as I care to go. (It's a fine thread so that extra full turn won't get it much higher). Then the fronts are set to match the fender-tire gap of the rear, although the fronts do have a good bit of upward adjustment remaining. (You could leave the rear where it is and raise the front higher, but it won't look right). If you need your ride height higher than this, then do not get the H&R Street Performance coilovers:
    I'll tell you, every time I start to focus on one solution, I get enough feed back that I start questioning the practicality of that choice. Like asking 100 cooks the best way to make chicken soup...
    That RS5 suspension idea is interesting. Any idea how much you dropped from stock with the H&R street coilovers? It's hard to tell from the pics?
    Thank you.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by boro92 View Post
    I'll echo this that the B12 pro-kit is a good option for a moderate drop. I run the OE springs with the same Bilstein (B8) sport shocks, and I'm happy with them. It's probably a slightly lower drop than the B12 kit, but close either way.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by Greygoblin View Post
    Thank you.
    I can't find my stock ground-to-fender measurements, but my current ground-to-fender measurement is approx. 25-1/2". If I remember correctly the stock height was somewhere around 27". I'll put it this way - I currently have approx. 1 index finger's worth of gap from the tire to the fender, front and rear, so that's maybe 1/2"-5/8" gap from fender to tire.
    Jan 14 2016
    Quote Originally Posted by SteveYem View Post
    That's helpful. I will check my car.
    I called ECS-TUNING for advice and one rep recommended MEGAN RACING Euro Street Series Coilovers. They:
    1) have a wider range of lowering and start at .5" which could be key for me;
    2) have adjustable Dampening;
    3) are only $900; and
    4) according to the sales rep are excellent, only priced so well b/c they are breaking into the European market and do not yet have the name.
    Anyone ever heard of them or have any feedback (the link is below)
    https://www.ecstuning.com/Audi-B8_S4...ing/ES2839063/
    Thank you
    Jan 07 2011
    2013 C300 4Matic
    Thank you
    megan racing is big in the JDM world. they are pretty reputable. I cant comment on those specific coils though. I had megan racing headers on my old g35 coupe, not that that helps lol
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Jun 19 2014
    toronto
    Megan racing coilovers are ...i dunno i drove a car with them and they were the worst suspension i ever sampled *this was on track*. The lack of rebound was so poor that the car was skipping sideways mid corner. The car would actually load up and unload so rapidly that the tires would chirp sideways as the car skips mid corner. Mind u , this was 5 years ago and they may have a better product now. But back then, whoa, it was bad.
    For less money i would buy the ecs cup kit. Or bilstein b12. Billy shocks are fantastic. As are koni yellow. The quality of shock is most important above all in any suspension package.
    Jul 21 2004
    South Florida
    Yeah I would not call Megan reputable. They may be recognizable but I wouldnt say reputable. There are dozens of JDM coilovers (Apex'i, BC Racing, D2, Greddy, Ksport, Omni, Skunk2, Tanabe, T1R, and GoPower) that are all made in the same Taiwanese factory alongside the Megans. The quality can be really hit or miss. If you contact that factory and specify you will order more than 100 units they'd be glad to pick out a color for you and build them to your "specs" and now you are a coilover manufacturer.
    BORO: Would you mind telling us a bit about your RS5 setup and how it has been performing for you? I'm interested in a factory type setup for my daily driver S4. I've been considering the B12 but the RS5 may work. Thanks so much.
    Mike
    2018 Audi S5
    Gone-
    Jan 14 2016
    Quote Originally Posted by bhvrdr View Post
    Mike
    Ouch, that's a pretty horrible review of the Megan. I too would like more info on the RS5 setup. Anyone know where, how much etc. Someone also suggested spring lifters, but that seems like a pretty lame solution.
    Feb 06 2012
    Allentown, PA
    Megan Racing's are not that great, why do you want coilovers to drop a .5"?! The whole idea of a coilover is that it rides well when lowered 1.5-2.0" , save money and aggravation and just buy a shock/spring setup. The Bilstein B12 Pro Kit is $800 for the shocks and springs. Done, install and forget about them, no jacking up the car to adjust every corner, worrying about corrosion on threads, etc, etc
    Jan 14 2016
    Quote Originally Posted by o1turbo30v View Post
    Am currently well below stock with my H&R sport springs. Problem is I am scraping terribly when entering my office garage (huge ramp) and occasionally the tires are scraping the wheel wells. Need to raise it up closer to stock.
    Senior Member Two Rings mavz's Avatar
    Apr 06 2015
    Mike
    I found his blog... he has a post about it here:
    http://dreamingin302ci.blogspot.com/...ion-on-s4.html
    Gone: 2013 Estoril S4
    APR - AWE - Vorsteiner - Continental - ECS - Akebono - JHM
    Jan 14 2016
    Quote Originally Posted by mavz View Post
    Anyone else with info on the RS4 suspension on S4? Also, any idea of cost and a good source other than an audi dealer?
    Established Member Two Rings nickskeeta's Avatar
    Nov 30 2014
    Hollister, Ca
    Megans are horrible, had them on my Mini Cooper and swapped them out eventually....
    I have H&R OE springs on my B8 with stock struts. It rides like the stock suspension, just slightly bouncier on bumps. The drop is nice, I have 19x9.5 et40 wheels and have never rubbed the tires once and my front bumper clears parking curbs+steep driveways. Although I am considering H&R coilovers to close up the the wheel gap just a tad bit more and improve handling.
    @nickskeeta
    2011 S4 6MT Meteor Gray Pearl
    2018 Silverado 6.2 LTZ
    May 17 2012
    Houston, TX
    I wouldn't trust anything a vendor says, at least not everything. They need to sell product and when you are not knowledgable about what you want they will sell you anything
    Jan 04 2015
    Northeast
    Quick parts search shows ECS has an RS5 shock/strut kit for $1170, plus springs (R 8K0511115CM / F 8K0411105CP) priced @ $180 each (only a few dollars less than Audi list price). so you're looking at $1,890 in parts if you were to buy new. That's only $200-$300 less than a set of PSS10s or V3s, which isn't a great deal IMO. Best bet is to try to find someone selling used...
    Jan 14 2016
    Sticking my finger under the fender, I would say my winter tires are either flush with the fender or even 1/8" higher than the fender. That has to be much lower than the 1.5" average drop H&R says to expect when using their sport springs. The H&R Street coilovers start at 1" and while I have been told that you don't want to keep them at the max height, I think I could set them higher than the car currently sits and be closer to a true 1.5" drop from stock. The problem is that if it remains too low, I am screwed (having paid for springs + labor, then coilovers + labor) and still have the problem unresolved. In that event, the only other thing I can think of is installing skid plates. If I am just scraping a skid plate as I enter my garage every day, I won't mind so much. Anyone know anything about skid plates?
    Thank you
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Thank you
    http://www.audizine.com/forum/showth...num-Skid-Plate
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Jan 14 2016
    The ECS skid plate only covers the front; when I raised the car on a lift, it looks like the area that is scraping the most is the underbody liner (the long plastic piece) about midway from front to back. I need something that will cover that area. I wonder if there is one out there or if making something custom with sheet of aluminum makes any sense.
