Originally Posted by
boro92
Sounds like a combination of problems. Imo:
1) tire compound is not suited to the temps. We are talkimg about an a/s here. They work but you cant expect the same performance in 50 deg temps as you would in 65 deg temps.
2) sounds like you are entering the corner too hot. When the car is pushing, are you adding more steering angle, are u on or off the gas? Answers to this would address this aspect.
It is not pushing due to increased chassis stiffness up front. OP is going too slow to load the car enough for any of that chassis brace stuff to have any effect. It's probably a combo of driving style and tires.. ..though an alignment can address most of these issues
it's even while driving slow, so it's certainly not coming into corners too hot. i drive the same, monotonous route to work every day and i've never felt out of control with the previous summer setup (toyo proxes t1 sport)
Moto One
First off you are driving a hammer with all he weight out over the front axel. Second it's all wheel drive so every wheel is taking a different ark, and depending on how fast, and what wheels are getting power "it's going to push, aka understeer" Take a rear wheel drive car, put a locker diff in it and the rear wheels now want to make the car go straight..Physics. Then as noted there is drive input? How he balance the car entering the turn, how much steering input and them throttle input. Can all cause understeer. Back to driving an all-wheel drive with to stiff of a front bar/springs and guess what? Can all cause understeer. The facts look like you big problem is your just driving to hard for conditions an the Car so far has been saving your butt.
Mark
as noted, we're talking u-turns, turning from a side road onto a main road, low speed on-ramps, etc. i'm not over-driving the awd.
snow tires are getting mounted this weekend. i'll report back if there's similar problems afterwards (which there shouldnt)
