Results 1 to 38 of 38
    Jul 21 2004
    South Florida
    12.210 at 112.88mph for B8.5 S4 DSG with Chipwerke Stage 2 and intake on pump 93 ...
    Well we finally got a bit of a break in the weather in S FL yesterday. It got down into the mid 60s finally so I headed out to PBIR and met with a few other forum members. It was great to see you guys, Hawkpilot6060 (B8 S4), B18b1ex (B8.5 S4) , Kyros (B8.5 S5), and Sciblades who had his RS7 there.
    We had the opportunity to run a CW Stage 2 car with intake versus a Revo Stage 2 car with intake and cooling. Very good results for everyone.
    It was absolutely packed last night so in 3 hours I was able to get in 2 runs.
    My car:
    Chipwerke S Stage 2 Piggy
    AWE 2.266" Pulley
    Injen Intake
    That's it. No other power mods. Stock cooling. 1/2 tank of 93 fuel. Stock DSG that shifts at 6400rpm.
    Best Run: 12.210 at 112.88mph
    I'm sure we will get better ambients in FEB too so there is definitely more left in it but i'm very pleased with the results. For about $600 in mods I have a car running low 12s. Too cool.
    Again, it was great seeing some other Audiziners there and great to meet you guys.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Nice. How did you do against the Revo car?
    Jul 21 2004
    South Florida
    Thanks guys.
    Same ET as the Revo Stage 2 and he trapped 1.5mph faster. His car had cooling and LW rotors but otherwise we had very similar mods (we both had intakes and stock exhaust). My 2015 DSG shifts a hair sooner than his 2010 car. Pretty evenly matched i'd say. I think his car had a 12.1 or better in it easily but we only go 2 runs in and we both ended up at 12.2. Both of us had also run (separately and previously) in crappier summer conditions and our best had both been 12.4x before that.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Hey Mike,
    Great run, I'm not sure you got my message but after they finally cleared the idiot charger that went into the sand, I managed to squeeze out a second run, a 12.77 @ 107. I'm not sure there much left in mine, but we will see if we ever get to log it. I was great seeing you guys.
    Jul 21 2004
    South Florida
    Hey Sean,
    Thanks man. Im glad you came out even though it was crazy there. You're trap is looking better. We just need to log and find out whats going on. We'll get it.
    Mike
    2018 Audi S5
    Gone-
    Nov 10 2014
    Apex, NC
    thats a sexy 60ft
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    yeah those are very good results. Very good to when you consider how much more difficult it would be for the car to be flagged than a software flash or am I totally wrong about that?
    Jul 21 2004
    South Florida
    Quote Originally Posted by doug97gxe View Post
    thats a sexy 60ft
    Thanks man. I'm no expert in the 1/4 mile and had been just running whatever tire pressures I already had on the car (usually 38psi) but Hawk pointed out to me that we should drop our pressures and I dropped to 32psi and it did seem to make a difference. Thats my best 60ft so far.
    Quote Originally Posted by Thurston View Post
    Piggies are extremely hard to detect. They dont modify the stock code. They dont alter the flash counter, the WSC code, the flash dates, and they wont trigger any "event logs" such as exceeding max rpm (if your tune alters the rev limits or removes the top speed governor) and wont show any torque, boost, etc values exceeded. They are pretty stealthy.
    Mike
    2018 Audi S5
    Gone-
    Mar 10 2015
    New England
    Quote Originally Posted by bhvrdr View Post
    Thanks guys.
    Mike
    That makes your time look even better.
    Apr 27 2015
    canada
    Thanks man.
    Mike
    plus with the savings in money from not having to go have this installed one (probably significantly cheaper out of the box as well) could put the extra towards lw wheels and other items and get a little closer to 12.0.
    What about the butt dyno compared to your friends Revo or w/e tuned car?
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Not sure a Stage 2 piggy car is any less likely to get a TD1
    Jul 21 2004
    South Florida
    Hawkpilot's revo car looks to run really well. Keep in mind we both are running 93 octane with stock cats and exhaust in place (not that exhaust mods are huge but 15hp is 15hp).
    The thing is that we are both likely running the maximum amount of boost and timing for our conditions so they are going to be relatively evenly matched. Little things like differences in DSG redline, weight differences (I weigh less than him, he had LW rotors, we may have had different fuel levels in the car, etc), tire compound and size differences, etc are what's a play. In addition, cooling is something I would consider next for my car if I keep it...but then it detracts from the OEM nature of my car. People touched the SC on each of our cars and his was apparently noticeably cooler. That would be a nice upgrade to do performance wise.
    Both cars were running really well from what I could tell.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings Batman0424's Avatar
    Dec 11 2015
    2020 SQ5, 2020 Audi Q3, and 2010 Mini Cooper S
    Hopewell, NJ
    Mike,
    I have been following your posts since you first experimented with the CW. I have used PBs before and always found them to be a nice, simple alternative to flashing the ECU.
    I do have a couple questions regarding the Stage 2. I currently run the Stage 1 (CW Pro set to 5/1) and have been extremely happy with the performance (after resetting). No issues with shift lag (2015 S4 with DSG) and no codes. I notice with Stage 1, power is much more noticeable above 3-4k RPMs (I have read this as being normal for Stage 1 tunes, including CW). Now, onto the questions:
    1) With the CW Stage 2, is there noticeable gains / smoothness at lower RPMs?
    2) Do you have any concerns with Stage 2 with the CW? Any indicators that safety controls would not prevent engine / SC damage?
    3) Where did you find the AWE pulley? I looked on their site and only see a full kit as an option.
    4) For servicing, etc, do you have to remove the pulley or is this not really noticeable?
    Thanks for the help..
    Jul 21 2004
    South Florida
    Quote Originally Posted by Batman0424 View Post
    Mike,
    Hi Batman (that feels really weird/good to say)
    1. Adding the pulley just makes the car feel like there is more power everywhere, particularly down low. Its been a really nice addition.
    2. My logs look excellent for safety. I'm very very pleased with how my car logs in the worst of the worst temperature and driving conditions. Every car is different though. If you run crap 91 octane your timing logs will look a lot different than anyone with 93 octane. All engine safeties continue to work perfectly with CW in place. The car will retard timing, will open the bypass valve, and will even go into limp mode if knock/temperature thresholds are met. I would always recommend data logging though with a modified car. Only data logs can tell you if YOUR car is running safe.
    3. I just happened to find the AWE pulley used and had been looking at it bc thinking of going GIAC stage 2. If I were just going to buy a pulley, i'd buy the CTS pulley. Its a tiny hair smaller and should work the same. From what I am told they also now manufacture it WITHOUT their company logo on it and in black to look OEM.... finally! Confirm with them though.
    http://www.ctsturbo.com/cart/product...-4793-688.html
    4. I leave the pulley on. Up to you. I dont have anymore dealership services scheduled between now and when I likely give up my car though so its not too much of an issue. It was really nice though when last month I had to have my car towed to the dealership. I removed the CW literally as the tow truck arrived and the car went into the dealership stock.
    Mike
    2018 Audi S5
    Gone-
    Apr 27 2015
    canada
    Quote Originally Posted by GRUMPY-S4 View Post
    can you elaborate? because of a pulley? I mean you may be spot on I just think it's an issue we aught to figure out.
    Really good numbers regardless for not messing w/ the ecu
    Not sure one could run many different octanes w/ much success and / or e85 though w/ out a software flash.
    Nov 10 2014
    Apex, NC
    it won't.. only way to tell is to physically measure the pulley and nobody is going to do that
    Present:
    Oct 14 2012
    Empty...for now...
    SE PA
    I'm currently awaiting delivery of my Stage 2 tune package, but I really wish I could have made the CW 'S' box work for me. I just could not tolerate the non-linearity of when the box "kicked in", plus the slight hesitation that would happen a moment after getting on the throttle. I have to say, though, that the added torque was noticeable and I'm sure it would have decreased my drag strip time (had I ever cared to try that), while sacrificing the refinement of the stock engine output.
    SOLD 2015 Daytona Gray S4
    Apr 27 2015
    canada
    Quote Originally Posted by SteveYem View Post
    good stuff. I could give 2 shits about driving a 1/4 mile as well. I thought there were some dyno graphs in another thread, i may take a gander at the curve.
    Nov 29 2013
    Silver Spring, MD
    Great time. For those that spent a lot more only to be a few tenths quicker (if that), has probably got some of us shaking our heads, lol. So, the piggy, pulley, and intake...that it?
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Mike
    Did Hawkpilot's car have the Revo DSG tune? I'm skeptical on how well the Revo DSG tune performs.
    Sidenote, If I set my Revo tune to the stock map do you think it would work with a CW?
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jan 04 2015
    Northeast
    Nice results Mike!
    I am running the CTS pulley and mine came in anodized black without a logo on it. However, I did order mine at around the same time Tony@EPL was doing his holiday group buy and I read in that thread that he requested an order of CTS pulleys without the company logos, so I'm not sure if I just got a pulley from that particular run or if that is now standard. I would double check with CTS before ordering.
    I have had very little time to log the car since I installed the pulley, but generally speaking the logs I have done look pretty good. Timing looks good and temps look good. The car pulls a little bit of timing up to -4 degrees on 93 winter blend. My ambients have been really good though...all sub -1000 DAs. I am bypassing up to 10%, but it's because I'm actually exceeding requested boost levels even with the attenuated signal. I have noticed the car leans out a bit on throttle tip in when going WOT for about 3/10ths, but looking back at my older logs I believe this was happening pre-pulley with the CW on 5-1 as well. Stock the car maintains lambda of 1.0 during tip in and enriches down from there. With the CW I seem to get up to 1.2 lambda before the ECU processes the feedback from the O2 sensor and adjusts fuel trims. I believe this has been discussed before in the locked thread.
    I will probably switch over to a stage 2 flash at some point, but I'm waiting to see how the beta dual pulley setups run before I make a decision.
    Jul 21 2004
    South Florida
    Quote Originally Posted by fitzydude View Post
    You have the Revo tune so I'm not sure why you'd try CW but if you were just wanting to run an experiment and SPS your car back to stock mode and run the CW and then run your car in Revo tuned mode that should work fine. It would be a cool experiment to do a "versus" comparison. One thing I have thought about doing is when I get the dual pulleys I may flash stage 2 and then run the CW on top of it to keep the bypass valve completely closed. I'm guessing there could be a lot of power there to be had.
    Thanks for the feedback J.S4. I'm going to do the same and try out the dual pulley first. I noticed my actual boost is now meeting the target boost levels now too in these ambients. My target boost was at 1750mbar but now is down to 1650mbar in this cooler weather. The OEM computer clearly changes its boost targets based on load/ambients, etc. It's clear this car has a lot left in it because I am bypassing a bit of boost now in the cooler weather too.
    Mike
    2018 Audi S5
    Gone-
    Jul 21 2014
    United States
    Impressive results. Are you still running the CW-S with the original (non-updated) map?
    Dec 19 2014
    Virginia
    I'm thinking about a chipwerkes for my wifes land rover disco sport. Overall what is your opinion on it and who can I contact about it
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Nice!! That 60' is outstanding if you are on street tires...my caddy usually cuts 1.6 on mt drag radials!
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 30 2015
    Sacramento, Ca
    Is this a common issue?
    Sep 20 2013
    DC Metro
    Mike,
    Nice work! All your time and methodical approach to everything is huge benefit to the community. It is much appreciated!
    '14 Audi SQ5
    '15 Audi S4
    Jul 21 2004
    South Florida
    Quote Originally Posted by GTItoS4 View Post
    I'm using the "stage 2" map now. It make the actual boost read even lower to work with the pulley and keep the bypass closed.
    Dudeman, i'd just contact the chipwerke guy, Murat. I dont know now they work for turbo applications but he seems really cool about returns as far as not charging restocking fees and being no questions asked.
    Tom, thanks so much man. I appreciate the kind words.
    Mike
    2018 Audi S5
    Gone-
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by BlownOne View Post
    Quite a few people have experienced a hesitation after shifting, but there are plenty that don't have the issue. Seems to be hit or miss.For those that experienced it, changing to a less aggressive map/setting on the CW sometimes fixed it.
    It's the only real drawback of the Chipwerke. Worth a shot though.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    This. the power was great but it sucks that i couldn't get around the non-linearity and hesitation after every shift. This set up saves lots of money over other tunes.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Hey, Mike,
    If you talk to Murat, can you tell him to reply to my emails and phone calls? Trying to return my CW or change it to fit the wife's car depending on his answers, but absolutely no response from CW since the week after Christmas. At this point I'm probably going to return it without support or response from him.
    Thanks man!
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Jul 21 2004
    South Florida
    Hi Jimmy,
    Yeah, I've only emailed with him a half dozen times. Last time was when I got the stage 2 maps. Never tried his phone number. I use the "info@xxxx" email address whenever I have initiated contact and he has responded within 24 hours. Weird. Let me know how it works out.
    Mike
    2018 Audi S5
    Gone-
    Aug 12 2013
    Lexington KY
    Mike
    Great results buddy. I'll say, every time I see a new post from you in regards to studying and testing your chipwerkes box, I get all giggly remembering when it first came out and you took the plunge. All the a holes who came out of the woodwork that would wine and complain, lol. I love it that you've had such great success. I just need to get off my cheap tail feathers and order one already.
    Thanks for putting all the time into this thing brother and great work.
    O
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by tgsweat View Post
    I get slight hesitation (car is stock) going WOT in all gears where it shifts, hesitates, drops 100rpm, and continues.
    This is exactly how my dsg behaves in the video below. Starts at 12 seconds.
    https://www.youtube.com/watch?v=DRM-N-kfIDY
    Is this the type of non-linearity you guys are talking about? If so, I will probably take the plunge with the Chipwerke + pulley.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Nov 05 2011
    maryland
    12.210 at 112.88mph for B8.5 S4 DSG with Chipwerke Stage 2 and intake on pump...
    Quote Originally Posted by shoe3k View Post
    https://www.youtube.com/watch?v=Am0Qa-2Ow8E
    This video shows more of the behavior but mine was slightly worse.
    http://youtu.be/Am0Qa-2Ow8E
    Its like power is cut for about a half second after every shift when using part throttle. Its more pronounced when you are actually driving, but the video gives you an idea.
    When i say non-linear, i mean the power is input is not smooth. After about 3.5k rpm, there is a surge of power suddenly...which is not a bad thing, its kind of a fun feeling. I just prefer the smooth power input, like how the car feels stock. I went with GIAC and the car is butter smooth during a pull....but at a higher cost of course, but it was well worth it to me. Not knocking the chipwerke, just didn't work well with my car. Lots of people have success, like in this post.
    Jan 12 2013
    Jupiter, Florida
    Mike,
    That was a good night, wish it was not as crowded and the 1 hour delay did not happen. Your chip works definitely seems to be working well! I ran a 12.203 with a not best 60 foot time. I am headed back out Wednesday and hope for an 11.9xxx! My revo tune seems to be doing fine, no TCU tune. Take care! And thank Carlo for the video! That new Taurus sho ran a 12.6.
    Qwik Rick
    2017 Audi Q7 w/APR stage 2, Vast TCU, RocEuro,
    2018 Audi Q7, stock for my wife.
    Sold
    2010 S4 w/Revo Stage 1+ tune & USP intake, cold front, lw crank pulley, JHM rotors
    12.44 @ 113.56 @ PBIR 1/4 (stage 1)
    12.203 @ 114.28 PBIR 1/4 (stage 1+) 13 Jan 2016
    Active Member Two Rings European90's Avatar
    Apr 09 2015
    Camarillo,CA
    Very good Run Mike
