    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    strange noise after installing aftermarket radio
    i have a 99 a4 2.8 quattro with bose system
    after i installed the radio some noise started to come from the rear'
    kinda sounds like the supercharger buzzing
    at first i thought it was something wrong with the fuel pump but after i turned of the radio it seemed to stop
    the strange part comes in that the buzzing is just like the supercharger
    the higher the rpm the louder the buzz
    any clues what could it be?
    this is the radio i have right now
    http://www.crutchfield.com/p_130X680...T.html?tp=5684
    Sep 02 2008
    Boonies VA
    Typically a bad ground / ground loop is going to cause that exact sound.
    White Wagon
    Dec 29 2015
    B5 S4
    Illinois
    so should i find a better ground or what should i do?
    Dec 29 2015
    B5 S4
    Illinois
    pulled the radio out and found of of the ground cables that attaches to the radio body was disconnected, hopeful this fixes it :)
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by CoyneJ View Post
    Yep, although...
    Hopefully that fixed it for you :)
    White Wagon
