Results 1 to 11 of 11
    Nov 23 2014
    North Carolina
    homelink range reduced in the cold
    So, I've been observing an interesting phenomenon. For some reason when the temperature is less than 40, particularly under 35* my range of working my garage door opener is greatly reduced. Before I could open the door from 200 feet from my driveway. in the low temps described above I can't even make it register at the end of my short driveway. I can be no more than just outside the garage door for it to work. Tested on my F150 and my Audi TT and no change in their distance, just the S4. Any insight?
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Mar 21 2015
    I have issues with mine at any distance and any temp. I could be sitting in front of the door and it still won't open. Seems like it doesn't want to work for a week then works great a fair amount of time. I can't get it to open no more than 75ft ever.
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    That's weird, my range gets longer in colder temps and shorter when hot. Same with my Infiniti.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Odd. I haven't noticed any change in homelink range with the cold (it's about 20 degrees here).
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    This for me too. I have moved mine a little bit but its still near where it was originally. Im trying to tie it to my phone somehow since I have smartthings hub.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Shrinkage.
    Jul 16 2012
    Mid-Atlantic
    Mine has been much shorter since it got colder.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Mine completely stopped working about a year ago.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Nov 23 2014
    North Carolina
    I was going to reprogram it, but since the range changes with te temp i dont think it will help. maybe i'll add it to button two and see if it makes a difference. might also elongate the antenna to see if it might help. sucks nobody else is seeing it. I was hoping for a potential fix.
    2019 X3 M40i - Sold
    Aug 15 2014
    OP funny you mention this. I too noticed the distance decreases. I have to be in my driveway now for it to work. no issues with my yukon
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Hm, seems the same for mine no matter the temps.
