Results 1 to 13 of 13
    Apr 25 2014
    CO
    tail light out warning
    about every 3 starts I get a left tail light out warning on the DIS.
    I have taken the tail light out, cleaned the contacts, checked the wires, it's all fine, bulbs all work.
    When I get the warning, if I turn the headlights and front and rear fogs on, it goes away.
    It's pretty annoying, can I just code those off with a vag-com?
    Oct 16 2008
    South Florida - Ft Lauderdale
    Nope
    Phil
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Seems like you've done everything but change the bulb. So change the bulb it's like $4
    Apr 25 2014
    CO
    Quote Originally Posted by adam044 View Post
    it's more like $20 since you have to change all 5. Yeah, did that....
    Oct 31 2014
    NH
    Oh, I'd sell it.
    Veteran Member Four Rings Pat_McGroin's Avatar
    May 09 2010
    Downey Ca
    I have the same issue, my gf was driving behind me a few nights ago and calls to let me know my left taillight was out. I didn't have a bulb out warning or anything though, got home, took a look and everything was fine, all lights were on. After that night, I would get a bulb out warning every once in a while but would go away on its own. I ended up changing all the bulbs but nothing changed, I was leaving work the other day and as soon as I turned the car on the warning came on, I took a look and this is what I saw. Had the dealer check it out when I went in for service and was told the connection was corroded. Perfect excuse to purchase LED taillights.
    https://youtu.be/qK6f7RWUmnM
    Rick
    B5 S4 StageIII
    Sold:Brilliant Black 2008 S4 Avant Tip.
    Gone but never gottin - Ibis 2010 A3 2.0T
    Jun 30 2009
    Washington DC
    I had the same problem. The hot wire on the female connector was loose. Loose connection probable caused several arching event which let to a burnt male pin.
    Cleaned the male pin with sand paper and applied a good coat of dielectric grease. This may work for you.
    This is also a temporary fix. I do plan on connecting a new harness, but it is near impossible to fine the avant specific tail light harness anywhere.
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    I had a similar issue on my Avant. One of the connector pins was corroded. Looked like water had been getting into the plug. The plastic bulb base which includes the male plug receptacle was pretty cheap from GAP.
    Iirc the plug is pretty standard is it not? You could also find the female pin connector from an electronics supply place like digikey and splice it in. Actually easy to do.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Are you sure you checked the right tail light - with all the lights on? There's four separate bulb carrier brackets.
    Apr 25 2014
    CO
    Quote Originally Posted by allstock View Post
    every single bulb functioned. There's actually 5..... 4 in the tail light assembly and one in the trunk lid...
    Apr 25 2014
    CO
    Oh, I'd sell it.
    I plan to, which is why I want to not get a flag on random starts.
    Apr 25 2014
    CO
    Quote Originally Posted by drewgold View Post
    I'll check them again
    Apr 25 2014
    CO
    Quote Originally Posted by pkny View Post
    I'll be damn, on closer inspection, happened to mine too.
