Results 1 to 12 of 12
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    Custom Exhaust - Parts Confirmation
    Hey guys, so I'm planning to do a custom exhaust for the A4 from a single sided to quads. The plan is to delete the resonator on the downpipe, replace the center resonator with a magnaflow one, attach a y pipe to split it into the magnaflow mufflers in the rear. My understanding is that the stock exhaust piping is 2.5inch all around. Since the muffler is a 2.25 inlet, would this work with 2.5 inch piping? Or would I have to find a muffler that has a 2.5 inch inlet. Same question for the y pipe. It's 2.5inch single to 2.25 dual, would I need to get one that is 2.5 to 2.5? Asides from these, and getting the exhaust hanger and heat shield are there any other parts I might need?
    http://www.hottexhaust.com/Magnaflow_10416 - Center resonator
    http://www.hottexhaust.com/Magnaflow_14816 - Rear muffler
    http://www.hottexhaust.com/Magnaflow_10758 - Y pipe
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by Chanman94 View Post
    Can you put staggered tips on that rear muffler? Even tips look odd with the rounded rear valence.
    I would find a 2.5" inlet muffler so I didn't risk choking the exhaust flow.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Jun 09 2014
    Calgary, AB, Canada
    Quote Originally Posted by blbroo View Post
    I might be able to if I buy a muffler without the tips, and source the tips separately. I'm okay with the even tips. But I will look for a 2.5 inlet muffler.
    - Richard
    Veteran Member Three Rings Carlos74's Avatar
    Mar 31 2014
    Palatine, IL
    In my case I ended up not using a heat shield and we decided to use only one MagnaFlow muffler in the center (13288). The downpipe and resonator were replaced with a 3in straight pipe.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    APR l CTS l EUROCODE l ECS l 034 l PODI l GFB l MAGNAFLOW l H&R l SPC l STANCE l SPULEN l HANKOOK l NGK
    IG: c_lowsB8
    Jun 09 2014
    Calgary, AB, Canada
    Do you have any sound clips of your setup? I thought about not having rear mufflers, but was afraid it might be too loud. Or that it might even drone, but with a centre resonator that might not be too bad
    - Richard
    Mar 31 2014
    Palatine, IL
    https://youtu.be/tnmcY46HML4
    I ran this setup for a while but I thought it was a bit too loud so a couple of weeks ago I decided to add a magnaflow resonator before the muffler and it actually quiet down nicely during cruising but I still get that nice growl when I go wot. I will try to make a new vid with the new set up as soon as the weather gets nicer.
    IG: c_lowsB8
    Jun 09 2014
    Calgary, AB, Canada
    Quote Originally Posted by Carlos74 View Post
    Thanks. So did you completely remove the downpipe and just have 3inch pipe from the cat to the center resonator? Or did you just remove the downpipe resonator and add piping from there. Because I thought the downpipe was also 2.5inch not 3inch.
    - Richard
    Veteran Member Three Rings goreckless's Avatar
    Aug 17 2009
    Stamford, CT
    Soooo...in like 3 months?
    2014 Audi A4 | 6MT | Brilliant Black | S-Line
    APR | AWE | Eurocode | CTS
    Mar 31 2014
    Palatine, IL
    The 3in pipe comes from the cat. To make things easier, we kept the stock downpipe flange and we used a 2.5 - 3 in coupler to run the 3 in pipe down to the muffler
    Quote Originally Posted by goreckless View Post
    Haha.. well its supposed to be around 40F by the weekend so that's nice enough!!
    IG: c_lowsB8
    Jun 09 2014
    Calgary, AB, Canada
    - Richard
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    Wow, i would love to see those parts when put together. Keep us posted on what comes out of it.
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    We're excited to hear what it'll sound like once you're finished! It shouldn't make a huge difference, but we would recommend using the 5x8x24" Y muffler for the center, and the 20 inchers for the 2 rear ones. It usually works a little better sound and space-wise. If you have any questions about sizing for your setup, feel free to call or PM us!
