Results 1 to 24 of 24
Thread: S3 Stalls
    Active Member Two Rings McFarland's Avatar
    May 30 2015
    S3 Stalls
    Has anyone had problems with your S3 stalling? I was backing out of a parking space last night. The S3 stalls and dies. Put back into Park, starts back up with a weird idle. Any ideas?
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by McFarland View Post
    Get your car scanned for any engine error codes. Did any of the lights come on in the dash?
    -cW
    2023 X3 M40i Alpine White
    May 30 2015
    -cW
    No lights came on. I had the dealer scan and they couldn't find anything. This is starting to happen a lot.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    What's a lot? When did it start and how often does it now occur? Any commonalities as to when the car stalls (for instance is it always when backing up)? How old is the car? If this is really starting to happen a lot I suggest you start raising hell at your dealer service center.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    May 30 2015
    I've started noticing a trend. It happens when I get gas, backing out of a parking space or pulling forward out of a space, when I dip below half a tank. It's a 2015, she's a year old this month. The dealer told me maybe water in the gas. I travel all over the metro DC, every station can't have bad gas. It happens about 3 times a week. I'm going to a different Audi dealer next time. I'm not pleased with my local one.
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    The trend you're noticing, especially after getting gas, sounds like that after a short stop (to get gas, or parking and running into a store) and then trying to restart the vehicle, the stall comes on. I had very similar problem in a previous 2.0T direct injected car (SS Cobalt) and to me it seemed like the car was vapor locking; I thought maybe an injector was leaking a tiny amount of fuel into the combustion chamber after shutoff, enough that over a short stop the fuel doesn't have enough time to evaporate, trying to start the car dumps more fuel into the cylinder, it vapor locks and the car stalls. Letting the car sit long enough for the excess fuel to evaporate out of the combustion chamber would let the car start.
    It turned out to be the high pressure fuel pump that was doing the leaking, the injectors themselves were fine, but the HPFP was leaking a tiny amount of fuel after shutoff that was flooding each cylinder just enough to vapor lock the engine after short stops. Do you smell gas a bit stronger than usual after a fill-up or after any short stop? If so that may be what's going on, these engines utilize a similar HPFP design. Mention the gas smell and that it only happens specifically after short stops the next time you take it in (if it's happening), any decent tech should be able to identify this condition based on the smell alone. Good luck!
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    May 30 2015
    Thanks. I appreciate your info. I'll do what you said.
    Feb 05 2011
    Pa
    I have an A3 less than 100 miles on it and it's in the garage for a new fuel pump. Same symptoms as your S3.
    Dec 21 2015
    Melhbach, Germany
    Quote Originally Posted by blk04ultraA4 View Post
    ^ This. But DC does have horribad gas. Always do your own research before taking your car to the dealer to give them a nudge in the right direction. Not all mechanics are superstars...
    2016 Audi S3 (CTS Intake, JB1, dogbone, AWE track catback..)
    2002 Trans Am WS6 (Sold)
    2012 SRT8 (Sold)
    1997 Viper GTS (Sold)
    2006 Z06 (Sold)
    2004 Viper SRT10 (Sold)
    2010 GT500 (Sold)
    Jul 17 2015
    Johannesburg South Africa
    Sometimes it's the start/stop. It'll switch off but force you to put the car in Park and turn the key to switch it back on. This usually happens in parking situations.
    Senior Member Two Rings montess2001's Avatar
    Jan 20 2008
    Westchester, NY
    Any luck on this issue?
    I recently began noticing a similar trend....Happened 2x in the last couple weeks. I'll go to start the car and all it does is crank several times. When it does fire up, it has a lumpy idle and will cut off. Eventually it starts up fine after several attempts.
    Current: 2015 SQ5 / 2016 ATS-V 6MT
    Mods: 034 Stg I + TCU / H&R+B8 / Neuspeed Rse103 20x9.5 et 25 / Carlinkit
    Previous: 8V S3 Daytona launch ed. / E92 M3 6MT / E39 M5 / B7 A4 Ibis 6MT Ti big turbo.
    Nov 13 2009
    the OC, SOCAL
    I think there was an older thread about some of the cars having faulty fuel pumps. its covered under warranty.
    Feb 05 2011
    Pa
    Update: Had a new fuel pump installed on the car and was still having issues. Problems got worse and almost got me into an accident as I was trying to merge on a busy highway. Engine fell flat on its face twice as soon as I got into boost. Car had only around 300 miles on it. I took it back to the dealer and demanded another car. I am now in an identical A3 and luckily have not had any issues so far...
    Feb 10 2004
    2009 A4 2.0T Sedan
    Yes, happened to me a few times as well. It's a known issue with the early build S3's, and apparently the A3's too.
    I've had my fuel pump replaced and thought all was good, until the other day when it happened again. Downshifted up an incline and whoops, EPC light came on and engine cut power. Was in the fast lane and had to pull to the left side shoulder on a bridge. It was idling rough, turned off and back on then it was fine. Previously before the pump replacement I stalled in a tunnel! It just loves to happen at the worst of times.
    The S3 is definitely the most fun to drive Audi I've owned so far, but also the least reliable.
    May 30 2015
    After going in circles with my local dealer, I'm now going to another one. I'm still having the same issue.
    Established Member Two Rings m3brad's Avatar
    Jul 22 2014
    Midwest
    Subscribed
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    we have had it happen a few times now on our S3. use to happen before and seems to have stopped. have little over 37k on the car. literally the first S3 here on the lots when they came out. wouldn't really call the S3 unreliable though. minor hiccup.
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Aug 06 2012
    san diego
    have you tried scanning it for codes? if no MIL its doubtful anything will show up on the scan but worth a try
    Nov 16 2015
    North Jersey
    I'm going to copy and paste my experience that I posted on another forum.....
    Problem:
    Ugh. Hey guys. So, my 2016 S3 did not have a good morning. Everything seemed fine until about 3/4 of the way into my commute when the EPC light came on. When I got off my exit for the parking garage, car had no power, was shaking, DSG wouldn't shift correctly or sometimes at all, and was on the verge of stalling. I made it to the garage and shut the car off. We'll see what happens when I get back to it.
    Needless to say, I'm not too happy about this. My last 3 cars have been Hondas and I've never had any problems whatsoever. This time around, I wanted to treat myself and get something nicer. I love the car, don't get me wrong, but this is already leaving a bad taste in my mouth.
    I've followed the break-in procedures as per the manual and have been really easy on the car. I'm hoping this is a minor issue and gets resolved quickly. More importantly, I'm hoping I can actually drive it to the dealership later today and not have to call Audi Roadside.
    "Solution":
    Well, the verdict is in, and turns out to be sorta my fault. It was bad gasoline. Normally, I fill up with either shell, sunoco, or BP(when I can find one). All good gas and never had a problem. This time, I put gas in at a Valero. They ran an analysis on the gas and found way too high levels of ethanol.
    Basically, the gas was crap and "watered" down with too much ethanol. The tech said there was so much he could actually smell it. They added some additive and also had to clean out the injectors which were contaminated.
    I was instructed to run this tank almost dry, fill it with good gas, and add one more bottle of the additive they gave me. Best of all, none of this was covered because it's not actually a manufacturer defect. So out of my pocket it came.
    Car ran fine on the way home from the dealer, but obviously I wasn't pushing it. So, lesson learned. It is kind of annoying though. The service guy said you won't notice anything if this was a Honda or Chevy.
    I've since been through that follow up tank of gas with the additive and one additional tank without the additive. Both fill-ups were Shell V-Power 93 octane. No issues at all since and power is back to what it was before this problem.
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by redwing497 View Post
    Problem:
    "Solution":
    Another forum!?
    But anyway, I'm calling BS on the dealer. It sounds like the exact same problem a lot of us have been having, and it's not due to bad gas.
    Nov 16 2015
    North Jersey
    I'm sure that's entirely possible, but since putting in Shell V-Power every tank since then, the problem hasn't returned. If it happens again, I'm going to be pretty mad.
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Unfortunately in Consumer reports besides audi moving up in the reliability ranks, the A3 is ranked the lowest in the brand.
    2016 Monsoon S3
    My slow build link - Onequick4door
    Jan 23 2015
    Westchester County, NY
    did anyone find a fix for this?
    CC
    Junior Member One Ring
    Feb 09 2020
    Any one end up finding a solution? Been experiencing stalls on warm start ups.
    LPFP already changed with no improvement.
