Results 1 to 8 of 8
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    OSIR Carbon Fiber dash trim (B8)
    Comes with the screen surround piece already glued on. Just pop off the old trim and put this on.
    Asking $300 shipped.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Is the weave the same as the stock carbon trim?
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Aug 02 2015
    Corning NY
    That's a good question. I no longer have my S4 but I believe it was the same. If not, very similar. If you pm me your number I can send close up pics
    Feb 15 2013
    Will it fit B8 S5? It should, but I'm not sure.
    If it fits I'm interested
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Quote Originally Posted by BlownOne View Post
    Somebody recently mentioned it was not the same 224 carbon weave as the OEM Carbon Atlas, hence why they got rid of it :)
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Aug 02 2015
    Corning NY
    I do believe it's really similar. But I never looked closely. Any of you guys mind posting up a pic of your atlas trim to compare? Lol.
    Idk if it's the same as the S5. Can anyone verify this?
    And sale pending.
    Aug 02 2015
    Corning NY
    Heres a close-up
    Aug 02 2015
    Corning NY
    Sold sold sold
