Results 1 to 7 of 7
    Jan 05 2016
    Car in Safe Mode after replacing to new key fob,WTF, HELP!!
    Replaced the key fob to a new one and car is now in safe mode, its starts for 5 seconds then shuts off...wtf!!!. I did all the chicken dance methods and non worked. Audi dealerships wants $150 for a new key. What should i do, searched but no answers.
    Jun 27 2011
    Your new key's IMMO hasn't been recoded to your car's IMMO. You can't just pair the key in VCDS and expect it to work.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 02 2006
    Wadsworth,OH
    Might have to hook it up to VCDS or a scan tool that can read ECU codes and clear the safe code. I had to do this with my B6. Some how I lost connectivity with the key and the safe mode wouldn't allow me to start the car no matter what I did. Once I cleared the immobilizer code it fired right up.
    Jason
    Jan 05 2016
    Ok so it seems like I forgot the "pill" in the old key fob and that's what kicked in the immobilizer. Can vag com clear the the safe mode? I have the Scan Tool Pro from ECS.
    Jan 05 2016
    Jason
    Would you know the steps to clear the safe mode in the menu of my Scan Tool Pro that i bought from you guys? I'm at the dealer right now and want to try it before I spend a whopping $154 for no reason.
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    You need to put the old pill in the new key
    Once that is done then you may need to lear the code.
    But don't bother clearing anything if you have not swapped over the chip/pill
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Shibidi View Post
    The V-checker?
    When you scan for ECU codes it should just pop up. It will say something about the immobilizer. Just go in and clear that.
    Hopefully the video helps!
    Jason
