Results 1 to 7 of 7
    Apr 06 2014
    las vegas, nv
    B5 S4 Noggy Blue Stage 3 + $12000 Las Vegas
    2000 Stage 3+ Audi S4. Nogaro Blue.161,XXX miles.
    $12000 OBO
    UPDATED 13 Jan 2016
    Engine-
    -SRM K24 Turbos / SRM oil lines (<3,000 miles on turbos)
    -DAZ tuned 91/E85 currently (have both files) must retune after meth kit install.
    --boost spikes at 30 PSI holds at 28 PSI
    -Walbro 485 Fuel Pump
    -Devils own Methanol Kit- dvc-30 stage 2 (needs to be installed) with dual d05 nozzles to APR bi Pipe
    -- 6 gallon tank in trunk
    -ICM delete
    -750cc Injectors
    -APR Bi-pipe
    -Forged 007 black diverter valves
    -AWE Side mount intercoolers
    -3? to 2.5" SSAC Down pipes
    -2.5" Custom Magnaflow dual exhaust
    -Goetze Piston rings 10/14/15
    -Valve cover gaskets 12/14/15
    - Half Moon gasket and cam caps 12/14/15
    -All coolant hoses replaced 6/16/15
    -Powersteering hoses replaced 6/17/15
    -New Bosch Alternator 05/07/2015
    -Serpentine Belt replaced 09/11/2015
    -RPM rods
    -New Clutch Slave cylinder with Stainless Steel braided line 5/15/2015
    -Porsche coolant and oil cap
    -034 intercooler silicone hoses
    -new N75 07/23/15
    -Bosch Platinum Spark Plugs 08/04/2015
    -New AUX fan Pulley / aux fan clutch / aux fan 09/10/2015
    -F hose delete
    -Spider Hose DIY mod
    -new N75 08/20/2015
    -Rotella T6 Motor oil
    -Bosch MAF sensor
    Suspension/Brakes /Drivetrain/Trans-
    -Clutch Net 6 puck clutch
    -17z Porsche Brakes (front) w/ Hawk Brake pads changed 08/03/2015
    -Stainless Steel Brake lines
    -KW ST Adjustable Coilovers
    -034motorsport density line control arm kit 02/14/2015
    -Rebuilt driver side axle torn boot 08/15/2015
    -Neuspeed rear sway bar
    -AWE Drivetrain Stabilizer
    -034 Street Density Motor mounts 09/21/2015
    -JHM Short throw shifter
    Exterior -
    -LLTek RS4 Mesh grills on bumper
    -re-sprayed hood, bumper, and fenders
    -Headlight washer delete on bumper (sealed with OEM material no bondo)
    -18x9.5 ET40 ESM-008 (special drilled 5x112) wheels/w 15mm hubcentric spacers all around (No Curb Damage)
    -Wheel locks
    -Cupra R lip
    -white LED plate lights
    -Depo E-code Headlights D2S 6000k
    -RS4 original Front Grille
    -Silver Painted Side Mirrors
    Interior-
    -New A/C blower motor 08/16/2015
    -Podi digital boost/AFR gauge(innovate) w/APR gauge pod center vent
    -Kenwood Double Din touch screen
    -Black leather/Blue Alcantara interior
    -All Weather floor mats
    -Black Alcantara shift boot w/ blue stitching
    -Greddy Turbo Timer
    -Aftermarket rearview mirror
    -New Rear window regulators replaced with bolts instead of blind rivets 09/17/2015
    -Fitted Windshield sun reflector
    Bad-
    -small tear rear passenger side seat of leather
    -heater core bypassed (heater not working)
    -caliper paint peeling off
    -roof top paint fading (could be paint corrected)
    Reason for Sale is to buy a house.
    Car is Beautiful inside and out. fast.
    Title in Hand; Clean. All maintenance has been done by previous Audi tech who works out of his garage. I have not got the chance to dyno it. I fixed all the problems on this thing. My loss, your gain.
    No test drives unless cash in hand. Serious inquires only! Please don't waste my time. If you have any more questions feel free to contact me at 702-202-eight 2 zero 4.
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Ive seen and worked on this car in person. The car is clean!
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Seen this car on CL for awhile, looks super clean and well built. GLWS
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    You can run that much boost on the Bosch mafs? Can you give me more info on the mafs, which sensor or housing.
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Pics don't work
    Sent from my E6883 using Tapatalk
    2008 Ibis RS4....GETing tuned
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    No pics
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Mar 02 2010
    Las Vegas
    Im good friends with the owner....the car is no longer available.
