Results 1 to 6 of 6
    Oct 24 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    C5 A6 water in the rear driver side footwell [FIX]
    In my 2003 C5 A6 2.7T I noticed the carpeting in the rear passenger footwell was getting soggy. I notice wet carpets seams to happen often enough for various reasons and figured I would put up a post incase someone did a search looking for the answer.
    My problem was that the grommet for the cable of the hood release came loose allowing water to come in. See picture below. I rectified it with a small long screwdriver. To give myself a little more room I opted to remove the ECU cover. Just shove that little round grommet back into the hole so that the sheet metal of the car fits in the groove and the grommet is snugly in place. Be careful as the first time I did it, I shoved the whole grommet in the hole by accident and had a bitch of a time pulling it out. Just be patient.
    Hope this helps someone.
    -Beck-
    2013 S5 Estoril Blue Crystal
    2003 A6 2.7T Silver
    May 20 2010
    Did you lubricate the cable to make sure it doesn't happen again?
    Oct 24 2006
    Houston
    Lubricate the cable; that seams like a smart idea, and no I have not.
    Guess I know what to do if this happens again. What type of lubricant would you recommend?
    -Beck-
    2003 A6 2.7T Silver
    May 20 2010
    Probably something as benign as WD-40 would work. Just need to run smoothly.
    Mar 01 2004
    1984 VW Rabbit GTI, 2008 Mk V GTI
    Greensboro, NC
    Thanks for posting this. My 2005 allroad gets water in the driver's pedal box after heavy rains. I just returned home from a trip and my car was at the airport. We had heavy rains and sure enough the carpet was wet. I'll check the grommet and hopefully mine is dislodged.
    Quote Originally Posted by scottyvee View Post
    Also check the sunroof drains, and the drain under the battery tray, they all get clogged and cause water to enter the cabin.
