Results 1 to 12 of 12
Thread: Need new tires
    Senior Member Two Rings Nate1616's Avatar
    Jan 24 2013
    CA
    Need new tires
    Hey guys, my PSS tires are shot and I need a new set. Looking at another set of PSS or p zero corsa if possible to get. Currently I have a slight stretched look at 285/30 20 on 20x10.5 wheels for my RS5. How can I get rid of this look. New size?
    2014 Audi RS5 coupe - Phantom Black | AWE Track Exhaust - Straight piped center muffler | Vossen VFS1 20x10.5 | Pirelli P ZERO 295/30 | 5mm spacers | 35% 3M Tint
    Previous:
    2012 Audi S4 - Brilliant Black
    2010 Audi A4- Ibis White
    INSTA: @blk.rs5
    Sep 28 2010
    NW NC / DE
    Odd a 285 PSS looks that stretched. There is a 295/30 PSS offering, as well as a 305/25 offering.
    I'd get an align once mounted too.
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    Does anyone know what the range for tire size would be for a 10.5" rim?
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Canadianwraith View Post
    265 to 315 are the acceptable sizes.
    Dec 30 2014
    London, Ontario
    Ah, many thanks Mops. I assume that the wider you go the more stretch (as seen above) you would get?
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Opposite. The more narrow the tire, the more stretch it gets on the wheel.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Sep 28 2010
    NW NC / DE
    Wider is a more square fit. More narrow gets you stretch as you see above. Here is a 10.5 with a 305/25 at the rear for example...
    Dec 30 2014
    London, Ontario
    Quote Originally Posted by i1overice View Post
    You are correct, the hamster in my head was walking instead of running.
    Dec 30 2014
    London, Ontario
    The setup on that Z is perfect Mops. I wish our dollar wasn't so shitty, need a set of rims in the spring
    May 09 2013
    Loads of junk.
    Northern Virginia
    Our S5's can run 305's too! :)
    Tyson's Asian Eric 1 by Jeremy Nguyen, on Flickr
    Dec 30 2014
    London, Ontario
    Yes, wider is better!
    Sep 28 2010
    NW NC / DE
    Hit me up when your dollar is feeling better :)
