Results 1 to 12 of 12
    Jan 12 2016
    Toronto, ON
    2015 Audi A4 6MT Shifting issues in cold weather
    Hey everyone,
    I picked up my 2015 Audi A4 about a year ago, and I've been noticing an issue with my gearbox when shifting from 3rd to 2nd in the cold weather. Shifting from 1st to 2nd is notchy/clunky, shifting from 2nd into 3rd is stiff, and downshifting from 3rd into 2nd causes a grinding sound and some vibration through my shifter. I've been driving a manual my whole life and have never come across this issue. I took the car to Queensway Audi where the shop foreman road-tested my car and ensured me that everything was ok with the car and the issue couldn't be re-created.
    Is there anyone else out there that has had this same issue?
    Dec 02 2014
    Dallas, Tx
    This issue only when the gear box is cold? Meaning, does it getting better after you've been driving a long time?
    Jan 12 2016
    Toronto, ON
    Quote Originally Posted by WCCoffey View Post
    It does get better after I've been driving for about 15-20 minutes, but this has happened to me twice before in the summer time as well.
    Dec 02 2014
    Dallas, Tx
    Quote Originally Posted by seemya4go View Post
    If its only when its cold out side, and goes away when the gear box gets good heat in it, I'd say the gearbox has too heavy a gear oil in it.
    Jan 12 2016
    Toronto, ON
    That's what I had suspected, because in my B6 A4, I had a harder time shifting in the cold but never had the grinding/vibrating through my gearbox. Because my car was out of warranty I changed my tranny fluid to Redline. But because my car's still within its warranty the dealership insisted that its the right grade gear oil. I might add that it still isn't very cold up here in Canada. It's only 23 Fahrenheit
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Happens to me too when the car is cold started and it's cold outside but loosens and smooths out in a few minutes as it warms up but hey, I'm in California.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Might be that someone put aftermarket transmission fluid in that doesn't meet VW spec. I swapped my fluid with Fuchs last month and have had no issues, even with the car parked all day at work when it was 12 F here. Still went through the gears like butter.
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    Been down in the 20's here in the AM and mine shifts just as good then as it does in the summer. As far as I know, I'm on OE tranny fluid.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
    Nov 10 2014
    Apex, NC
    mine does the same thing
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Checking in from a cold climate. No issues shifting. My old B6 A4 had heavier gear oil in it, and the slow shifts were very noticeable. I'd get the dealer to swap out the fluid, or at the very least have the car sit overnight so that it can be cold started...
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Jan 12 2016
    Toronto, ON
    If i'm going to swap my tranny fluid to aftermarket, any recommendations? I've seen Redline 75W80 come up a lot in the forums.
    Oct 26 2012
    St. Louis, MO
    This is working great for me:
    http://www.rmeuropean.com/Products/G...863-V5040.aspx
    Redline seems to have cold weather issues.
    http://www.audizine.com/forum/showth...n-Fluid-Change
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
