Results 1 to 27 of 27
Thread: Fit of despair
    Registered Member One Ring omnio's Avatar
    Jan 12 2016
    Fit of despair
    Hello Everyone,
    Endless apologies if I have started a thread that had already been addressed but I haven't found a satisfying answer to my problem yet. I have a 2004 A4 convertible 1.8T and I love this car to the max. I've picked her up not too long ago and she has some minor flaws I need to mend to make her perfect. One of those is a broken cupholder. I got ahold of a new one already but I can't, for the sake of my life find out how to remove that plastic trim right above in order to remove the broken cupholder.
    Here's a pic:
    http://kepfeltoltes.hu/view/160113/I...toltes.hu_.jpg
    I tried to pry it open but didn't work. During my researches I have gathered that a special Audi tool must be used in order to remove it but others reported that it can be taken off without that tool. Anyhow, I hope someone reads this who faced the similar problem and can give me a clue how to do it. Also, I could use some info about that Audi tool as well.
    Thank You very much in advance!
    Piece,
    Peter
    "You can have it in any color as long as it's black" - Henry Ford
    Apr 07 2011
    Jan 12 2016
    That was the main reason I have decided to start a new thread. Let me quote from the aforementioned post:
    "gently remove the surround with a putty knife..then you will see the holder". Now, I don't have a surround. The A4 convertible is different in a way that it has a panel ABOVE the cupholder not surrounding it. Here is an example for the surrounding version used in most Audi models:
    http://kepfeltoltes.hu/view/160113/m...toltes.hu_.jpg
    Mine is different as it can be seen on the pic I took:
    I have found numerous walkthroughs on how to change a cup holder with the >>surrounding<< panel, but I couldn't apply those tips on my model's different layout.
    Your answer customa4 is appreciated though!!
    Apr 07 2011
    So you're saying if you try to pry that upper panel off it doesn't come off?
    Jan 12 2016
    Quite frankly, no. I mean I have tried to a point I started to worry breaking that panel. I have a hard plastic prying tool designed for such operations and it didn't work. I've tried a flathead as well with the same results. I can certainly bend the plastic a little bit (and a bit more around the sides) but it seems this panel is fixed. I wouldn't venture to exert more power when prying b/c I don't want to break that plastic panel. I'm sure there's a trick to remove it though. Audi is great to use those tricks so if you want to get something done you have to take the car to the garage.
    Nov 11 2010
    Rochester, MN
    Start watching this video at the 1:42 mark. He shows to how to pop that panel off.
    19" B8 S5 Peelers
    Jan 09 2012
    MA
    Slick, I think the OP's problem is that he has a cabriolet and that panel does not exist. The cab dash is completely different if you look at the link in his first post.
    Apr 07 2011
    Quote Originally Posted by deyrag View Post
    Exactly^^
    Jan 12 2016
    Yeah that's why I'm asking if anyone knows how to remove that panel...
    Nov 11 2010
    Rochester, MN
    Does this help?
    19" B8 S5 Peelers
    Jan 12 2016
    Quote Originally Posted by SlickFix View Post
    Does this help?
    Great! Can you just please display the A680287 illustration for positioning those scrapers?
    Thank You again!!
    Apr 07 2011
    Does this help?
    You're the man Slick! Good ol' Bentley strikes again.
    Quote Originally Posted by omnio View Post
    Thank You again!!
    Here ya go.
    Looks like the tabs on that cover work the same way the cupholder tabs do. Just have to slide something in there to push the tabs up and it will slide out.
    Jan 12 2016
    Guys, I really appreciate! Will report back as soon as I can do the fix!
    Apr 07 2011
    Not a problem, Slick gets the credit here, I just Google searched the number he posted. Here's the write up from the workshop manual. Click Bookmark that webpage for the future, pretty much the factory manual for free. It's just a bit annoying to navigate but there's a lot of info there.
    Nov 11 2010
    Rochester, MN
    You are too kind, sir. I just used my online Bentley manual, which is in beta. But it has a lot of good stuff. Anyone who purchases the DVD of the Bentley manual can sign up for the online beta.
    19" B8 S5 Peelers
    Jan 12 2016
    Bunch of useful info and helpful folks. Love this forum :D
    Guess it has to do with the fact we all own and love Audis, haha.
    Apr 07 2011
    Hmm, first I've heard of an online beta, gonna have to look into that.
    Jan 12 2016
    Ok, I had been spending my day off to remove that darn panel but I could NOT find any tabs to be pushed in. First I've tried to feel them out based on the picture displayed here then, as the sun'd set it illuminated the whole dashboard from the back so I could see in there and there were no visible tabs. I'm puzzled! :(
    Any idea anyone?
    Piece,
    Peter
    Nov 11 2010
    Rochester, MN
    I'm afraid that we're going to have to hope that a Cab driver shows up to save the day. I don't think there are really tabs, per se. It looks like you shove the spacers in and gently pull out. Is it not moving at all?
    19" B8 S5 Peelers
    Jan 12 2016
    Nope it doesn't move at all. The Plastic bends, though, so I could peek underneath a little bit. This, combined with the sun light from the back allowed me to see that there's no tabs there. The scrapers can be shoved deep into that gap though. The images you were kind enough to post are pretty straightforward but following those steps that panel remain up in its place.
    Jan 12 2016
    Well, maybe those are not tabs, but there's something there on the A67-0287 image; something on both sides, located symmetrically. I'm sure I have to reach those with the scrapers. But I was unable to find anything on either sides.
    Jun 30 2008
    Erie, Pennsylvania
    Maybe this will help. I think you can see the clips that hold this bugger in there:
    Jan 12 2016
    So that's how this bad boy looks like. I assume I have to find those two "tabs" I have circled on the pic...
    http://postimg.org/image/k9cg9s3e5/
    ...will try again this morning!
    Thank you
    Jan 12 2016
    That's it, I guess I give up now! :(
    Jun 30 2008
    Erie, Pennsylvania
    What are you using to push down the clips? I think you need to use something "L" shaped. Like little hockey sticks. That way you push the clips down from the rear, which might be easier. I've taken the liberty of marking up the photo to show what I mean:
    Jan 12 2016
    I will give it a try walkytalky! I've read somewhere about a special audi tool that gets the job done. anyone knows anything about it?
    Apr 07 2011
    I find it hard to believe a special tool is necessary or it would be mentioned in the Bentley manual.
