I know the first thing most that enter this thread is going to say "what a fool, look at the head ID badge". Well I have and it says AEB. I am guessing someone along the way has swapped on an AEB head or swapped an entire aeb engine. I am wondering what the likelihood of that is and how I am going to be able to tell the difference? It does have a drive by wire TB and not a cable.
I need to be able to tell what the block is as I plan on pulling the engine and going through it completely, installing a new clutch, and then figure out which turbo I want to stick in her (most likely my 6758 but dp and mani options are limited).
I do have aeb engine I could swap in. I am wondering what all needs to be done to make it work as well? I am guessing simply swap over its accessories and your done.
