Results 1 to 12 of 12
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    Are there upgrad foglights available for b5 a4?
    The current ones on my audi are really screwed up, along with the windshield.. like they've been sandblasted over the years. The windshield I'm replacing; it's majorly cracked from the p/o slapping a wiper down. But it seems the OEM fogs are glass, which means i"m not sure if I can sand them down and slap lamin-x on them?
    In any case, are there aftermarket upgraded housings I can buy that illuminate better than stock? It seems the stockers aren't terribly wide or far out.
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    I guess I didn't know the oe fogs were glass. You can grind down glass lights but from what I've seen it doesn't really do anything compared to plastic.
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Nov 19 2015
    Buffalo, NY
    I'm not POSITIVE the stock fog-light lenses are glass, but knocking on them they sure the hell feel like it.
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    The stock lights are glass faced, and there is a DIY about refinishing glass foglights on a BMW, it involves hours of sanding with different grits and finishing with a heavy glass polish. Give it a google, it's possible
    And there aren't any aftermarket fogs no
    Sent from my E6653 using Tapatalk
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Jun 30 2008
    Erie, Pennsylvania
    I think the B6 guys were retrofitting B5.5 Passat projector fogs or some-such thing. Should be able to do the same thing on a B5. I mean, it's a pretty simple affair, as long as the housing fits within the space and you can figure out how to make it stay there, you can do whatever you want.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    zipties come to mind.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Get new lenses or refinish then retrofit some projector fogs in. Greg or someone will chime in shortly on what works best or search around.
    Search b5 a4 foglight retrofit in Google. Alot of diys ect
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    May 17 2014
    Raleigh, NC
    Ihave the RS4 bumper so not a very general test bed, however most oem fogs have 2-3 support bolts.
    Ive been planning on putting some Matchbox bixenons in my OEM rs4 fogs but havent had time. I might try retrofitting some LED fogs.
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    I retrofit HID projectors into the stock fogs. Works well.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    I bought a set of DEPO fogs. They are great quality for the price.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Senior Member Three Rings wolfe2118's Avatar
    Apr 09 2012
    Fort Wayne, IN.
    I did mine years ago on my first B5. I think I put them in the oven at a low temp., something around 100 degrees and the lense came right off. Used 1500 grit sandpaper and some sort of polishing compound on them. Glued them back together with black RTV.
    Nov 19 2015
    Buffalo, NY
    So if I were to refinish the stock housings and upgrade the bulbs, are they a decent setup? They are horribly sandblasted right now.
