Results 1 to 9 of 9
    Dec 19 2014
    Virginia
    bypass valve solution?
    nevermind lol
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Deactivated Three Rings
    Aug 24 2015
    Wouldn't that blow up the engine? Where/how would the over boost relief come from then?
    Sent from my iPad using Tap,Tap,Tapatalk
    Dec 19 2014
    Virginia
    Quote Originally Posted by S4NJ View Post
    well a lot of us are trying to get more boost I don't think we could possibly spin these charger to the psi to actually blow this motor up.
    me and a few others are on dual pulleys now and boost levels are not crazy high from what ive loged . the problem is the bypass valve is opening up top when we don't want it to.
    2010 s4
    Gone:
    Aug 24 2015
    I see. Ok, good luck.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    That's what an ECU tune does.....
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    There are definitely times when you want the bypass to open under boost, and you'd run into several faults related to keeping the bypass shut when the ECU is trying to open it. You're a lot better off just waiting for the tuning to catch up with the dual pulley setup. Every major tuner seems to be working on it (not sure on Revo).
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Dec 19 2014
    Virginia
    Quote Originally Posted by jran76 View Post
    I agree lol
    2010 s4
    Gone:
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Yep, what Jran said. If you are that eager, experiment with the chiperwerke lol. bhvdr seems to think you should be able to keep it shut with that... I'm going to wait and hope APR is willing to let me run the tune come spring. If that doesn't happen I'll explore other options...
    I'm really looking forward to what @andthen runs this week.. Think he mentioned going to the strip on saturday. Tony's cooking up some potentially good stuff at EPL from what I've seen. E85 and dual pulley, should be interesting!
    May 22 2015
    DFW
    Quote Originally Posted by mrmomo313 View Post
    So far the chances of rain have bounced around from 60-90% and now down to 20%. The track has posted that the event will be pushed to the following Saturday if this is the case. Still trying to perfect the tune. And I'm not sure if I'll have the cooling system installed by then or not. But if the weather is good I'm running it.
