Hi there again,
I have a couple of cuestions:
An ECU from a 96 A6 Quattro 2.8L A/T with the same part number of my 96 A4 Quattro 2.8L M/T ECU can be installed in my A4? And if it can, do I need to put some codes with VCDS or something?
The second question is related with the output test mode in the VCDS soft, I have the original interface and the licence, but when I try the outputs tests to the ECU the program skips the injector test part, the test begins with the fuel pump relay and continues with the differents solenoid valves (EVAP, EGR) and then says that the test is complete, I thought that the output test includes a injector trigger test, anything is wrong with my soft or ECU?
