Results 1 to 10 of 10
    Jan 17 2012
    '14 S4, '15 Subaru Forester
    Los Angeles, CA
    Has anybody repaired an OEM Ti rim from curb rash?
    It has been a while since I repaired a wheel from curb rash. So careful, but today, I f'd up.
    Are these Ti (part of the black optic package for my '14) wheels repairable? By repairable, I mean re-painted or re-finished.
    If so, is it spot painted, or does the whole wheel need to be done like a chrome finish?
    Jan 17 2012
    Los Angeles, CA
    http://www.audizine.com/forum/showth...eel+paint+code
    Found this thread, but curious if anybody has done the repair and if there are two different colors.
    thanks
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Depending how bad it is, they are difficult to repair since the lip and part of the face is machined. You can't use fillers. Usually repair shops just paint the machined surface to an aluminum color.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jul 10 2015
    SATX
    My wife has same finish on her wheels and Discount Tire messed them up. Fast forward And they can be refurbished to new condition but to do it right its more $$$. Bill was $600+ for all 4.
    They resurfaced the faces and also repainted and cleared the wheels. Turned out great! For a 2011 it was a nice free refresh!
    Jan 15 2012
    2016 explorer sport
    Sacramento CA.
    I had some curb dings on same wheels. My Audi dealership fixed them for free. I think they said it could cost something like $50 a wheel. They grind them down. You can't tell the results unless there pointed out.
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    I had one of mine done and it came out perfectly. The only noticeable difference is if you really look closely, the texture is slightly different in the paint. They used a 2nd wheel as a reference to get the machine marks on the lip correct and I'm very happy with the results. I had my friends at Fall-Line do it so I cannot speak from the experience of working through a dealer. I can tell you that I have seen "dealer approved" wheel refinishing companies working on the ground in the back lot of a dealer to "fix" wheels so I wouldn't be too confident going that route.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    My wife curbed one of the rims not the rotors but the other 19's and it cost 120 to fix it. They had to add material sand and paint it.
    Jan 17 2012
    Los Angeles, CA
    thanks, all. dealer fixing for 100-150.
    Aug 30 2013
    KY
    I had 2 curbed Titanium OEM rims fixed at dealer for $200 each. It was quick and now they look better than the other 2.
    SLOWER TRAFFIC KEEP RIGHT
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Refinishing a wheel properly is very difficult. In many cases the finish will end up flaking off in a couple of years, but if you aren't planning on keeping the car long then it is no big deal. Or if you just want it to look good. You can always have them redo it as well. Should run you around $100 per wheel.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
